compressor surge-what to connect blow-off hose to?
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
i just hooked up the greddy gsr kit with 11" intercooler and stuff into my hybrid hatch...i connected the hose from the blitz to the intake pipe side and not the charge side. i guess that is wrong because i am surging and not relieving. do i need to hook to the charge side? is that the same as t-ing to the intake manifold? help would be appreciated.
Re: compressor surge-what to connect blow-off hose to? (loturbohybrideg)
you need to t it off the manifold. You need to put to a good vacuum source.
Re: compressor surge-what to connect blow-off hose to? (b18bturbo)
yea.. T it off the intake manifold, mine did the same thing when i had it hooked to the fpr line.. on a seperate strong source it should work..
1 Post
Re: compressor surge-what to connect blow-off hose to? (GSRwBOOST)
thanks fellow boosters. i will try that and i'm sure things will be good. i'm new to hands on boosting. i did the install but was just unsure of that one thing, other than that i am pretty happy. thanks again.
Yajhershey
07-14-2013 07:50 AM
gnccracer18
03-24-2008 06:14 PM
