What's the Difference Between BPT and BSPT?
Old Nov 1, 2002 | 08:38 PM
inspyral's Avatar
Default What's the Difference Between BPT and BSPT?
What's the difference between BPT thread and BSPT thread? BPT is British Pipe Thread, right? Then, what's BSPT? The reason I'm asking is because I got a GReddy sandwich adapter to run my oil pressure gauge to, and I need to know what the thread is on the ports. One is M12, and the other two say "1/8 PT", which I assume means pipe thread, but I'm not sure what thread standard it is. I'm pretty sure it's not 1/8 NPT because I tried screwing in some Autometer 1/8 fittings I had lying around, and they didn't thread in very well, and neither did my 1/8 NPT tap(I just tried to thread it in lightly in order to not mess up the threads). I got my gauge used, and it came with a hose that connects to a 1/8 adapter and then to a coupling that adapts to the sending unit, but the other end seems to be missing a fitting, namely another 1/8 adapter that would screw into the sandwich adapter. If I can get a 1/8 to 1/8 male connector, I could just screw it into the sandwich adapter, and then screw on the coupling that adapts to the sending unit, and not have to deal with the hose. Does anyone know what thread standard GReddy uses for their gauges? Is it BPT or BSPT? Also, any ideas on where I can find a 1/8 male to 1/8 male fitting? Any help is much appreciated.
Old Nov 1, 2002 | 08:44 PM
Flamenco-T's Avatar
Default Re: What's the Difference Between BPT and BSPT? (inspyral)
the difference between the two is that the BSPT thread is tapered than the BPT.,..
I have some 1/8" NPT to BSPT adapter if you neeed one...male to male, aluminum..
Old Nov 1, 2002 | 08:49 PM
inspyral's Avatar
Default Re: What's the Difference Between BPT and BSPT? (Flamenco-T)
Ok, so BSPT is just more tapered? So which one does GReddy use? Thanks for the offer, but I don't need 1/8 NPT to BSPT. I either need 1/8 BPT male to male or 1/8 BSPT male to male, depending on what thread GReddy uses. This isn't oil feed for a turbo, it's for connecting my GReddy oil press to my GReddy sandwich adapter.
Old Nov 1, 2002 | 09:02 PM
Flamenco-T's Avatar
I believe greddy uses bspt...
Old Nov 1, 2002 | 09:07 PM
inspyral's Avatar
Ok, I guess I could just look for both a BPT and a BSPT fitting, and see which one works out. thx
stackz
Jul 28, 2017 05:05 AM
climb_on
Oct 5, 2007 10:40 AM
AzntaggeR
Oct 2, 2004 04:35 PM
RCautoworks
41
May 20, 2003 04:58 PM
inspyral
Nov 1, 2002 08:39 PM
