turbo RPM gauge...check it out!
Anyone ever seen one of these? I guess it a nice to have for those who wonder at what rpm their turbos start to spool....
trying to figure out how difficut it is to install one..
[Modified by MiraiZ, 1:16 PM 11/3/2002]
Re: turbo RPM gauge...check it out! (johnisenglish)
http://www.omorimeter.co.jp ...you'll need to go to the Japanese site...the English site doesn't carry it
Re: turbo RPM gauge...check it out! (FredoSP)
still trying to figure out where and how to install the sensor from this pic. looks as if it needs to be close to the compressor wheel...but whats that gasket near the wheel?
Re: turbo RPM gauge...check it out! (G)
Its the mount for the sensor......
if thats the case, does it replace part of the housing, or does it attach on to the intake port? can't figure it out
[Modified by MiraiZ, 4:04 PM 11/3/2002]
Re: turbo RPM gauge...check it out! (MiraiZ)
how is that pic confusing.. the sensor sees the turbine spinning.. like abs wheel speed sensors work. looks like you run the wires throught the pipe then out a drilled hole or something.
Re: turbo RPM gauge...check it out! (madeiniraq)
heres the english page...Its Japanese-English, so it makes very little sense...
http://www.omorimeter.co.jp/turbine-e.html
1 Post
This Meter is developed to measure Turbo charged car condition.
Turbo charged car, due to lack of oil control, occurs etching in turbine,
by adopting non-contact optical fiber sensor, make possible to protect
above trouble and by adopting pulse motor, make strong to vibration and
indicate correct display. Also contains CPU circuit which make possible Max.
okay... can someone translate that to more understanable english?
Re: turbo RPM gauge...check it out! (turbopanda)
[Modified by slowasshatch, 8:26 AM 11/3/2002]
Re: turbo RPM gauge...check it out! (slowasshatch)
Define understanable
Seriously, that is cool idea! They need a little help in the marketing dept for US customers though.
Sonny
Enjoy you product !
Hey might not be accurate but it sounded like it came straight from the source.
Re: turbo RPM gauge...check it out! (POLLO)
the more a I look at this thing, the more I want it...but it looks like some fabrication will be needed to the turbo..
Re: turbo RPM gauge...check it out! (dlplayboy)
I don't think its new, but I 've never seen it before...the only thing I'm concerned about is having that optical sensor being sucked into the blades...
[Modified by MiraiZ, 3:42 PM 11/4/2002]
It only goes to 20,000 RPM's...
Dont the T3/T4's spin much higher than that, like 100,000 RPM's (+/- 20,000 or so)?
Re: turbo RPM gauge...check it out! (xThexHeadx)
-a
Oh, and here you go for all of you who are not fluent in Engrish:
http://www.omori-na.com/catalog/spec...turbinerpm.htm
Once again at the forefront of instrumentation technology, Omori North America offers our turbine RPM gauge, equipped with an optical sensor accurate to 200,000 rpm. If you are serious about optimal tuning of your turbocharger system for peak efficency, this gauge will allow you to closely monitor the exact behavior of your turbocharger to tune perfectly within your chosen compressor's efficiency map. This is a special order item, contact us directly for pricing and ordering information. Also available in a white face.
______________
I guess I was correct with my above hypothesis in regards to what RPM it goes up to
-a
______________
-a
