first thoughts on AEM automapping
Old Nov 3, 2002 | 04:15 PM
Brian_92GSR's Avatar
New User
Default first thoughts on AEM automapping
Just started using my AEM EMS today for the first time and had a chance to use automapping. The map I had was really messed up due to my 3 bar map sensor and big injectors, so I made sure everything was very rich. Started right up and got the idle working right away. Did about an hour of driving, evantually getting it up to around 6000 rpm and 15 psi. Automapping worked great, didn't take very long at all to reach the target A/F ratio. Automapping only works above 5% throttle, so I'm still having some problems coming off the throttle.
Once I've got most of the map working well I'll post it on my website. There weren't any honda maps using a 3 bar map sensor. My inejctors are 720cc.
Old Nov 3, 2002 | 04:18 PM
CzanSOHC's Avatar
Default Re: first thoughts on AEM automapping (Brian_92GSR)
very nice, where are you located in Ohio, I'm in COlumbus.
Old Nov 3, 2002 | 04:22 PM
New User
Default Re: first thoughts on AEM automapping (CzanSOHC)
I'm about an hour from Columbus.
Old Nov 3, 2002 | 04:35 PM
CzanSOHC's Avatar
awesome, I'm thinking about EMS w/ my setup....right now I'm still trying to get my AFC tuned until I can get either Hondata or EMS this summer.
Old Nov 3, 2002 | 04:48 PM
falcongsr's Avatar
What is this crap?
its very likely that you'll need to tweak the accel fuel tables to add fuel when you press the gas off idle. i am still tweaking this - havent had a chance to fine tune - it working bigger problems.
Old Nov 3, 2002 | 05:28 PM
New User
Default Re: first thoughts on AEM automapping (falconGSR)
How exactly do you get to that table through the menus? I've looked through the fuel menu but I'm not sure which one you're talking about.
stinker504
May 29, 2007 09:08 AM
integraboosted
Mar 25, 2007 09:38 AM
88YellowRexSi
Nov 30, 2005 10:35 AM
int3gra
Jul 4, 2003 11:49 AM
DD_JonnyLee
Mar 3, 2003 03:37 PM
