finally I have switched over to the darkside....
well here is my car, been waiting a very long time for this moment... let me know what you guys think.. its kind of ghetto but it works great...
Re: finally I have switched over to the darkside.... (Hammett)
thanks,
drag mani, pt50 turbo, starion fmic, blitz bov, celica alltrac inj, supra tt pump, vafc, msd btm, tial wg 6.5lbs, fjo wideband, greddy 2mm head gasket, arp head studs
[Modified by BoostedED9, 4:47 PM 11/4/2002]
Re: finally I have switched over to the darkside.... (BoostedED9)
Nice Setup. How many pounds are you gonna run? And was the install of the Supra TT pump easy or did it require modification?
Re: finally I have switched over to the darkside.... (Just2Fast)
riight now im running 6.5lbs but prob gona turn it up soo. the pump was easy install, but i had to run new power wires for it b/c stock ones were getting too hot so i ran them straight to the battery with a relay with bigger gauge wire works great... heres a pic of the supra tt pump installed and i switched over my stock sock no modifications...
[Modified by BoostedED9, 4:52 PM 11/4/2002]
NICE.....
I am also interested in how the PT50 spools
what are the specs on your turbo?
I can't wait to build up my SC32 setup....
Re: finally I have switched over to the darkside.... (Bryson)
.60/.63 50 trim stage3 wheel & ported housings, ill check the exact rpm for its spool time b/c right now i have just been watchin the fjo display to make sure its not going lean
holy canoley...that thing is HUGEEE i wish i could get something like that for my piece...i love turbo so much!!!
Re: finally I have switched over to the darkside.... (RaceFacer)
what do you guys do about your o2 when runing racegas?? im runing a pump/race mix and i think my o2 is done already since im throwing a o2 code...
Re: finally I have switched over to the darkside.... (Ham'ed Hatch)
since switching over from na to this it a big difference makes me feel good
Re: finally I have switched over to the darkside.... (FredoSP)
taylor wires, running ngk 3330 plugs tho and i cant really hear the bov since im runing open dp right now
I'm looking foward to seeing it at the steak n shake meet. You'll be there right? I wanna see more SOHC turbo cars since Im turboing mine pretty soon.
Re: finally I have switched over to the darkside.... (DeepSi)
slowasshatch: i should be at the meet especially if girls are gona be there....
and the turbo doesnt rub on the radiator but i had to cut my fan and move it over to fit it.. im getting a slim fan so i can put my filter on
for spool up time it starts around 3200 but im running an uncomplete dowpipe that is open so that could be a factor for its spool time
[Modified by BoostedED9, 12:19 AM 11/5/2002]
Finally my son you have converted, MUHAHAHAHAHAH. Still cant hang with my fully built and sleeved monster , with a .70 compressor and .54 exhaust t3t4 powered crx!!!
Jason
Jason
Re: finally I have switched over to the darkside.... (spoon2)
well today tragedy struck.... something in my drivetrain is broke and im thnkin its the clutch, gona take the tranny off tomorow to inspect it further... i knew something was gona go wrong turbo was just feeling too good...
