how much boost on a d16 rods?
Old Nov 4, 2002 | 07:44 AM
Ya@inlinePRO's Avatar
Default how much boost on a d16 rods?
i'm broke and goin to school, your basic excuse for a ghetto bastard, anyways, my boy got some extra turbo parts aside and i plan to boost my DX hatch, stock dx motor, how much boost you guys think the rods can handle as a daily driver, and also anyone know of a manifold wit external wastegate for the d16? will the y8 turbo manifold fit on the y7 block? i'm tryin to keep this a non-vtec, and just run a y8 intake manifold...thanks
Old Nov 4, 2002 | 07:56 AM
Boostfed's Avatar
New User
Default Re: how much boost on a d16 rods? (kwik2nec)
SOHC rods are known to be very weak, usually a small shot less than 60shot nitrous or approx 7psi of boost depends on size of turbo of course. This is the general thumb I've seen but some people have proven it wrong. D series rods are very weak and thin but again we have an old 90 Si motor in a 90 hatchback junkyard turbo kit Saab turbo T3, DX exh mani, Deltagate, etc etc has run a best of 12.0 and many 12.20s with 15psi or so, he turned it up to 20psi t see if he could break into the 11's or blow it up but showed no improvement. He also put street tires back on and ran a 12.90. I used to think SOHC wasn't worth it but they can be made fast also. I'm waiting for the BS flaags now. I'm sure I can get the timeslips posted and some pics of the car too. All I can saay is Aaccuracy Automotive built the cara dn tuned it, also AFC and some 87-92 Supra Turbo 440cc injectors. I wouldn't trust more than 10psi myself.
Old Nov 4, 2002 | 07:57 AM
Finest's Avatar
Homemadeturbo.com has a few CRX's that's running 8-10psi on stock internals. I wouldn't push it past that amount, even with the AFC hack.
As for an ext WG on the manifold, try Drag or RevHard.
Old Nov 4, 2002 | 08:03 AM
Firedrake's Avatar
Default Re: how much boost on a d16 rods? (Prelude_RCR)
Our Y7 was making 200 whp at 14 lbs at 5500 ft elevation on the old 14B, since then we switched the turbo to a 16G, but I'm not sure how much he's running now and it hasn't been back to the dyno yet.......because our elevation is worth like 3 psi, I'd say 10-11 lbs is about the max you'd want to run....
Brian
Old Nov 4, 2002 | 08:09 AM
word, thanks a lot guys, some nice numbers i've been seeing from SOHC after searchin the net and what not, you guys think i should stick wit a t3? or t3/t4, or do you think the t3/t4 would be too much? thanks again
Old Nov 4, 2002 | 08:16 AM
Ri5e's Avatar
if you use a t3/t4, use the small one, .48 a/r
based13
45
May 11, 2013 03:58 AM
based13
May 3, 2013 09:25 PM
iiPancho
Apr 4, 2010 10:55 AM
crxpro
Dec 4, 2008 04:54 AM
vti96
Sep 16, 2006 03:59 PM
