Problem with my Check Valves...!!!HELP!!!
Old Nov 1, 2002 | 07:45 PM
B18PoweredCivic's Avatar
Default Problem with my Check Valves...!!!HELP!!!
I have a 96 ex coupe with an LS turbo swap...I get a code for my Map sensor when I do the diagnostics...I have an obd1 ecu you w/ obd2 - obd1 harness...It seems like my check valves look fine..It hase one side that goes to the map sensor and the other to the throttle body.. and then 2 check valves in between..why do i still get a code?...Should I reset my ECU if so how do I do that?
Old Nov 1, 2002 | 08:19 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Problem with my Check Valves...!!!HELP!!! (B18PoweredCivic)
Get a missing link and dont worry about check valves anymore.
bennyhonda7
May 11, 2005 11:38 AM
Pengo
Jul 30, 2002 08:43 PM
turbotec
Feb 26, 2002 03:34 PM
Teluan
Sep 3, 2001 07:29 PM
