lsvtec JRSC needs injectors.
I am wondering if I should use 450cc or 550cc RC injectors with a SMC. Right now I am running very lean with Prelude injectors and the JR map, fuel pump, FMU, BTC, and Vpac. Will 550 be over kill.
I have a JG lsVtec (2033cc displacement) and a JRSC running a CRV pulley. I see 10 - 12 psi peak boost on my Autometer gauge. If you could help me out or know anyone with the same set up, I would greatly appreciate it!
http://www.rceng.com ues the calculator for your needs and it will tell you what size you need. personally i wouldnt boost unless you have some better injectors.....
Blaze
Blaze
anything over 370c are going to be difficult to control with just bandaids. For your setup you'll be fine running 370c. Perhaps 440 but the 550 will be really really hard to control with only the mods you stated. Just my 2¢.
RC440's and the SMC would be the simplest route and will meet your needs. If you go larger than 440's, a resistor pack is required. See my sig.
Sonny
Sonny
2K Teggy
Oct 28, 2005 05:09 AM
