help picking turbo on a b20a
Old Nov 4, 2002 | 07:44 AM
dwn-shift's Avatar
Default help picking turbo on a b20a
I cant decide from a t3/to4e 60 trim w/ .82a/r or should i get the t4 60-1. I am using a b20a prelude motor. 81mm bore with 9:1 comp. I have forged pistons/rods. Head has a port and polish, crower dual springs, titiaum retainers, stock valves, and stock cams. I will also be picking up a zdyne gold ecu.
I am looking for whp in the 400-450hp range.
thanx
mike
Old Nov 4, 2002 | 09:00 AM
HybridKOOP's Avatar
Default Re: help picking turbo on a b20a (dwn-shift)
Neither. The T3/60-1 would suit you perfectly. The T3/T4 even with the .82 would be stretching for your HP goal... The T4/60-1 IMO is too large for your application. Do the T3/60-1 with like, a .63 and you'll be good to go.
Old Nov 4, 2002 | 09:25 AM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: help picking turbo on a b20a (HybridKOOP)
i agree. the t3/60-1 will be perfect for your application. the t4/60-1 is way too laggy.
Old Nov 4, 2002 | 11:13 AM
ArizonaTurbo's Avatar
Personally, I like the T3/T04E with teh following specs:
.82 A/R
Stage III
.60 A/R
60 Trim
This turbo can easily support 500 whp. With 9.0:1 CR you should have full boost by 4000-4500 rpms. You will have way more top end with a .82 A/R then with the .63 A/R turbine housing. The T04E compressor is more efficient than the 60-1 also by 2-3%.
Old Nov 5, 2002 | 07:05 AM
dwn-shift's Avatar
Default Re: help picking turbo on a b20a (TurbochargedSER)
I think i made up my mind, i will probably be getting the t3/t04e. It seems to be more efficiant. Hey cheapturbo.com i saw your prices they are to good to be true, i will be buying my stuff from you in a couple weeks.
Old Nov 9, 2002 | 01:35 PM
C-Murdock's Avatar
.82 A/R
Stage III
.60 A/R
60 Trim
Inform them LOUIS !!!
Old Nov 9, 2002 | 07:02 PM
dwn-shift's Avatar
Default Re: help picking turbo on a b20a (C-Redrum)
inform me what?
Mugencrxsir1
Feb 26, 2006 04:17 PM
kriptik
Feb 18, 2005 11:04 AM
DeeJay
Apr 2, 2003 07:58 PM
Ri5e
Aug 24, 2001 07:59 AM
