2.5" downpipe -->> 3" cat : how does it work?
Old Nov 3, 2002 | 02:46 PM
Pat's Avatar
Pat
Default 2.5" downpipe -->> 3" cat : how does it work?
I'm wondering what is the way to bolt up this junction?? Do I need to use a 3" flange on the downpipe or do I need a different flange on the 3" cat that would fit the 2.5" flange on the dp. Another way I heard is to flare the 2.5" dp to 3" at the end. TIA
Old Nov 3, 2002 | 03:21 PM
Precision DC4's Avatar
Default Re: 2.5" downpipe -->> 3" cat : how does it work? (Pat)
bump, i have this same question
Old Nov 3, 2002 | 03:38 PM
DeepSi's Avatar
Default Re: 2.5" downpipe -->> 3" cat : how does it work? (BlackIntegraLS)
either you will have to flare the downpipe from 2.5 -> 3
-or-
redo the cat and have a 2.5 -> 3 adapter flange put on.
Old Nov 3, 2002 | 05:44 PM
morepoop4u's Avatar
Default Re: 2.5" downpipe -->> 3" cat : how does it work? (DeepSi)
this is what i did https://honda-tech.com/zerothread?id=312216
Old Nov 3, 2002 | 05:46 PM
B18C-RnVA's Avatar
New User
Default Re: 2.5" downpipe -->> 3" cat : how does it work? (morepoop4u)
i have one for sale...standard drag downpipe..with welded 3inch straight pipe( NO CAT) with 02 bung welded on....pm me..make offer..its in great condition...
Old Nov 3, 2002 | 07:39 PM
magicwand's Avatar
Default Re: 2.5" downpipe -->> 3" cat : how does it work? (B18C-RnVA)
where can I get a 2.5" to 3" flex pipe for my downpipe?
Old Nov 3, 2002 | 10:12 PM
Flamenco-T's Avatar
Default Re: 2.5" downpipe -->> 3" cat : how does it work? (magicwand)
do this....
go to muffler shop, ask them for a 3" 3 bolts flange, then have them get a 2.5" piping about 3-4 inches long and have them use a pipe expander to make it 3", so now you have a 3" 3 bolts flange and 4" of piping flaring from 2.5 - 3"
have them weld the 3" side of the piping to the flange
now, go to autozne and get a flex exhaust kit, it's about 5 bucks, comes with 2 secure band...
hook up one side of the flex pipe to your DP and the other side to the 2.5" side of the flange
voila
stan
Old Nov 4, 2002 | 10:05 AM
Pat's Avatar
Pat
Default Re: 2.5" downpipe -->> 3" cat : how does it work? (Flamenco-T)
thanks for the suggestions
B18C-RnVA - thanks but I'm already gonna use a Max Rev dp
BlueShadow
Welding / Fabrication
May 20, 2005 06:35 PM
BlueShadow
Feb 2, 2005 04:05 PM
b18c4door
Oct 12, 2003 06:43 AM
xci_ed6
Aug 19, 2002 06:17 PM
Etylorcen
Oct 23, 2001 11:55 AM
