Tial or Deltagate
Old Nov 4, 2002 | 08:51 AM
7rrivera7's Avatar
Default Tial or Deltagate
I'd like to go turbo for XMAS and wanted to get feedback on Tial vs Deltagate wategates...
Old Nov 4, 2002 | 08:54 AM
EP3_05's Avatar
Default Re: Tial or Deltagate (7rrivera7)
From my extensive reading of past posts...most guys prefer the tial wastegate as opposed to the deltagate. It seems that the deltagate tends to spike a lot.
Old Nov 4, 2002 | 08:55 AM
Adi Radoncic's Avatar
On Fire!
Tial all the way,
Better design,
No spike problems,
Nicer look....
Adi
[Modified by newgsr, 11:55 AM 11/4/2002]
Old Nov 4, 2002 | 08:58 AM
DC2R714's Avatar
Default Re: Tial or Deltagate (91civic)
IMO if you are not going to use an electronic boost controller go with the Tial because there are sometimes spike problems with deltagate. If you are going to have an EBC, it is just preference because they both will work fine. My friend had a Deltagate with an AVC-R and it never had problems unless he took it off and ran the spring then he spiked. I have the Tial and I never spiked with the spring now I have the AVC-R.
Old Nov 4, 2002 | 09:01 AM
01ITR#700's Avatar
Default Re: Tial or Deltagate (DC2R714)
I'd go Tial personally, sleeker look and no spike problems that I'm aware of. And with the deal you can get from Viren it's well worth it!
M
Old Nov 4, 2002 | 09:05 AM
HybridKOOP's Avatar
Default Re: Tial or Deltagate (01ITR#700)
TIAL, although it sounds shitty when it opens when vented to the atmosphere...
Flamesuits zipped... but c'mon guys, it sounds like a dunebuggy/lawnmower.
Old Nov 4, 2002 | 09:19 AM
01ITR#700's Avatar
Default Re: Tial or Deltagate (HybridKOOP)
This confuses the **** outta me. I run the TIAL WG with a badass little dump tube that shoots down towards the ground. I can't hear a damn thing other than the motor and the low key stock exhaust. Is this noise everyone is referring to more audible from outside the vehicle??
M
7rrivera7's Avatar
Hey thanks for the quick responses guys...
Four questions:
1) It sounds shitty? I thought it was the blow off that makes the swishing noise? (and I was thinking of getting an HKS SS)
2) What is spiking?
3) I was thinking of replacing my MSD 6AL with the 6BTM. Is this what you refer to as electronic boost control?
4) Who's Viren?
Thanks again!
[Modified by 7rrivera7, 6:35 PM 11/4/2002]
Old Nov 4, 2002 | 10:27 AM
Etylorcen's Avatar
1. The turbo does make a swishing sound but also when you actually start to boost you can hear the wastegate open up and start dumping. Some people like the sound others dont. You'll moost likely smell it if you dont hear it.
2. Spiking is when your boost is at a certain level and it doesnt hold and jumps up. Often caused by deltagates. Spiking is a common cause for blown motors.
3. The 6btm just controls spark and retards timing with respect to boost. Its not an electronic boost controller. The avc-r and greddy profec b are electronic boost controllers.
4. Viren is b18bturbo.
InLimbo87
Aug 11, 2004 05:58 AM
BoostedH23a1
Oct 20, 2003 11:06 AM
ebp 99 si
Jun 15, 2003 07:45 PM
TJ R
Feb 5, 2002 04:08 AM
