Timing
Old Nov 4, 2002 | 07:36 AM
dwilson's Avatar
Default Timing
Can someone tell me what the correct timing mark is on a B18b? I am trying to set it to stock spec, but my book doesnt tell me which line to use there is four lines. In this order black, red,black, and then white. Which one do i need to use to put back to stock spec.
Thanks in advance, D
Old Nov 4, 2002 | 07:49 AM
boostaholic's Avatar
Default Re: Timing (dwilson)
The far white mark is 0 degrees BTDC. The red one is 16 degrees BTDC, the stock timing mark. The black mark between the white and red is 14 BTDC and the other one is 16 BTDC.
Old Nov 4, 2002 | 09:11 AM
dwilson's Avatar
Default Re: Timing (boostaholic)
So the red mark is stock timing? Also you said it and the far left black mark, both are 16 BTDC. Is this correct? So if i want to retard two degree of timing i would run it on the black mark between the red and white mark correct? Sorry for all the questions, but i am going to have my hondata tuned this wkend and need to have it all dialed in stock. Thanks again, D
[Modified by dwilson, 6:15 PM 11/4/2002]
Old Nov 4, 2002 | 02:58 PM
Correct, the red mark is for stock or 16 degrees BTDC.
White - 0 degrees BTDC
Black - 14 degrees BTDC
Red - 16 degrees BTDC
Black - 18 degrees BTDC
Old Nov 4, 2002 | 03:28 PM
Blaze45's Avatar
Brrraaaap!
i have a B20 and I dont see ne timming marks on it ne where. Ne help would be rad.
Blaze
Old Nov 5, 2002 | 04:04 AM
dwilson's Avatar
Default Re: Timing (Blaze45)
They are on the very back belt drive closet to the motor
Old Nov 5, 2002 | 01:35 PM
Blaze45's Avatar
Brrraaaap!
thanks
Blaze
blackbndt
Oct 4, 2009 10:20 AM
d15b7racer
May 7, 2006 04:10 AM
GQ Cowboy
Dec 20, 2003 11:00 PM
smkngsr
Apr 15, 2002 05:36 AM
