Back from the TRACK again!!
Old Nov 1, 2002 | 09:20 PM
TurbothisLS's Avatar
Default Back from the TRACK again!!
well I think my clutch is going out...it's starts to slip in 4th and 2-3rd shifts....
but here goes:
BEST 1/4 MPH:
reaction - 1.0991
60 ft - 2.4769
330 ft - 6.5214
1/8 ET - 9.7175
1/8 MPH - 77.08
1000 ET - 12.4649
1/4 ET - 14.7733
1/4 MPH - 100.04
BEST 1/4 ET:
reaction - 0.7742
60 ft - 2.4052
330 ft - 6.3380
1/8 ET - 9.5049
1/8 MPH - 78.03
1000 ET - 12.2380
1/4 ET - 14.5416
1/4 MPH - 99.62
comments welcome....
clutch was slipping so i babied it out of the hole
this was at 7 psi of boost and SAFC Hack
[Modified by TurbothisLS, 6:22 AM 11/2/2002]
Old Nov 1, 2002 | 09:24 PM
CzanSOHC's Avatar
Default Re: Back from the TRACK again!! (TurbothisLS)
good times dude, what you running for rubber? what size wheel?
Old Nov 1, 2002 | 09:31 PM
Default Re: Back from the TRACK again!! (CzanSOHC)
16" rotas
with 205 40 16 falkan aziex h-rated
Old Nov 1, 2002 | 09:32 PM
DIRep972's Avatar
Smarter than you
u reallly need traction.
Old Nov 1, 2002 | 09:33 PM
Default Re: Back from the TRACK again!! (DIRep972)
yeah i wanna try lowering my tire pressure....but i'm not sure what to drop it too and i don't want to slip my clutch any more than it already is
Old Nov 1, 2002 | 09:44 PM
SiRkid's Avatar
yeah, you need traction..9.7 8th...ouch.
Old Nov 1, 2002 | 09:53 PM
Default Re: Back from the TRACK again!! (SiRkid)
why was my mph so high on that run, but the time so slow?
Old Nov 2, 2002 | 12:59 AM
Mr. Softee's Avatar
Default Re: Back from the TRACK again!! (HellSing)
2.47 60 foot MIGHT explain it
Old Nov 2, 2002 | 01:00 AM
Etylorcen's Avatar
Default Re: Back from the TRACK again!! (94goldjungsr)
Traction is a bitch with turbos we all know it. He just needs some practice and stickier tires. 100mph trap is
Old Nov 2, 2002 | 03:00 AM
senpai's Avatar
but here goes:
BEST 1/4 MPH:
reaction - 1.0991
60 ft - 2.4769
330 ft - 6.5214
1/8 ET - 9.7175
1/8 MPH - 77.08
1000 ET - 12.4649
1/4 ET - 14.7733
1/4 MPH - 100.04
BEST 1/4 ET:
reaction - 0.7742
60 ft - 2.4052
330 ft - 6.3380
1/8 ET - 9.5049
1/8 MPH - 78.03
1000 ET - 12.2380
1/4 ET - 14.5416
1/4 MPH - 99.62
You're better than my 2.6xx 60 foot, haha! You can hit AT LEAST low 14's
Old Nov 2, 2002 | 03:21 AM
degradated's Avatar
New User
100 mph trap is pretty good. However, practice. With 2.1 60' times you should be able to get that down to a 13-8-13.9.
Also, are you running a 3" exhaust, test pipe, etc? If not, that will help, as well as a heavy duty clutch. Drag radials would be nice too. Then up the boost to 9 psi and look for low 13's.
Old Nov 2, 2002 | 10:40 AM
Default Re: Back from the TRACK again!! (degradated)
thanks for the tips guys.
i'm running a 2.25" itr exhaust with high flow carsound
my tires suck and i think i need to drop the pressure, but my clutch was slipping so i didn't wanna try anything too crazy
Old Nov 2, 2002 | 11:13 AM
DIRep972's Avatar
Smarter than you
get good tires(at least azenis) and a clutch and u will have no excuse for not running a 13, other then just flat out bad driving. good luck man u can do it
Old Nov 2, 2002 | 07:57 PM
cool, i'll give a new clutch a try, however, it will be awhile
Old Nov 2, 2002 | 08:27 PM
BoM's Avatar
BoM
clutchmasters stage 4 are pretty cheap. and really good!
elrandeeto
May 18, 2005 06:57 PM
anothaRRR
May 1, 2005 02:31 PM
B18C1CYA
Jul 26, 2004 08:15 PM
B18C1CYA
Jul 26, 2004 03:26 PM
lilcasino
May 4, 2003 04:22 PM
