3 bar map sensor with EFI PMS? HOW?
I was wondering since there is a spot for the 3 bar on the harness... what do i do about the stock one specially since won't the stock one break after 12 psi?
please help me thanks
the 3bar map function on the pms is only used so that the pms unit can read boost. it is used in conjunction with the stock map sensor. use check valves or a missing link for the oem one.
so how do i boost more then 15 psi?
i have to run check valves on the stock sensor and just have the 3 bar hooked up to the pms?
