has anyone blown their engine @ 10psi or less w/correct fuel management?
I have my wastegate at 7 right now, and it seems to be doing fine. rich at WOT with hack and 450's. so, if my fuel supply is fine, is it ok to bump it up a little or do i need to build? let me know. thanks!
Re: has anyone blown their engine @ 10psi or less w/correct fuel management? (BoostInBoi)
what motor do you have? also, do you have a fuel pump?
[Modified by gsR-T mode, 7:34 PM 11/2/2002]
You really need to get the car on the dyno to tell if fuel delivery is correct. Guessing is just going to break things.
Re: has anyone blown their engine @ 10psi or less w/correct fuel management? (dustin)
ditto on what dustin said. dont get boost happy unless you plan on having it tuned on the dyno, thats where you will gain the most power at.
Re: has anyone blown their engine @ 10psi or less w/correct fuel management? (GudeH23a)
would smc + 450s and a digital 6 count as somewhat of good fuel management?
Re: has anyone blown their engine @ 10psi or less w/correct fuel management? (blufke)
Re: has anyone blown their engine @ 10psi or less w/correct fuel management? (ion_four)
dig 6 + cap - 230
smc - 100
injectors - 90
techedge kit - 100
vx o2 sensor - free
520
hondata -500(right?)
injectors- 90
tuning - kinda pricey
at least 750 and id have to drive to someone who could tune it for me.
and the digital 6 does do retard per lb.
smc - 100
injectors - 90
techedge kit - 100
vx o2 sensor - free
520
injectors- 90
