Simple question, oil pan weld on bung, steel or aluminum?
Re: Simple question, oil pan weld on bung, steel or aluminum? (filetofit)
steel, easier to weld...aluminum tends to melt easier...
you can pick up steel fitting for cheap...
Re: Simple question, oil pan weld on bung, steel or aluminum? (Flamenco-T)
My gsr is steel, but I think some civics come with aluminum. put a magnet to it and if it sticks, get a steel bung. If not then get an aluminum.
Guest
Posts: n/a
know you could weld dissimilar metals. Or did I misunderstand?
i think you can, but it takes longer and is harder, but i am not a welder so i might be wrong.
Just for you, i put a small magnet to it and it stuck, so i guess that means it is steel. i have a 2000 civic si
-deepsi
-deepsi
Re: Simple question, oil pan weld on bung, steel or aluminum? (SiRkid)
you cannot weld aluminum to steel. you have to get the type of bung that is the same metal as your oil pan.
I figure this would be of help:
http://www.anplumbing.com/shop/shop1...op=&dept=Steel
-10 Steel Weld Fitting (PN#967110) $4.83 each..
http://www.anplumbing.com/shop/shop1...&dept=Aluminum
-10 Aluminum Weld Fitting (PN#997110) $5.11 each
Re: Simple question, oil pan weld on bung, steel or aluminum? (Midwestrider)
You cannot weld aluminum to steel.
I even tried once to see what would happen. hehe.
Re: Simple question, oil pan weld on bung, steel or aluminum? (dustin)
ok, i ordered everything on this list
https://honda-tech.com/zerothread?id=232145
i am confused now.
will i be ok with what i ordered.
(ive got a 00 Si, so i think its a steel pan)
i am confused now.
