Help! bogs after i shift...
Old Nov 3, 2002 | 06:29 PM
KoRE's Avatar
Default Help! bogs after i shift...
When i shift from first to second it boggs ....
I have a:
d16z6 greddy turbo 11psi
lightened flywheel
action clutch
9.4:1 comp
is it just the lag? or should i just upgrade my valve train and just shift later then 7000-7200
help thanks
Old Nov 3, 2002 | 06:41 PM
gtfourmn's Avatar
Default Re: Help! bogs after i shift... (KoRE)
Hmm... Well what I did to fix my lag problem with rev higher.. it seems to work.
Old Nov 4, 2002 | 07:03 PM
KoRE's Avatar
Default Re: Help! bogs after i shift... (turbine)
k thanks that's what i thoguht anyone else?
Old Nov 4, 2002 | 07:42 PM
BoostedD15B7's Avatar
might be a fuel problem. Have you had it dyno tuned? what kind of management do you have? Possible checkvalves. What are you running for that? Missing link? AFC?
Old Nov 4, 2002 | 07:51 PM
Loco Honkey's Avatar
Default Re: Help! bogs after i shift... (BoostedD15B7)
Bingo. If you're using an FMU, it's the FMU playing catchup when you transition from vacuum to boost. Ditch that POS and go AFC or SMC.
Old Nov 5, 2002 | 11:43 AM
KoRE's Avatar
Default Re: Help! bogs after i shift... (House of Boost)
i got the afc hack already but the UPS Guy just brought me my EFI PMS
Old Nov 5, 2002 | 12:31 PM
bQQsted hybrid's Avatar
hey KoRE! i sold you the PMS.
i had that same exact problem. i took out some fuel (with the PMS) and bingo, the problem was solved. depending on your setup, you may be able to my program on setting 3 as a starting point and go from there. i was running around 8 psi with 550cc injectors.
Old Nov 5, 2002 | 01:43 PM
DLB1994's Avatar
Default Re: Help! bogs after i shift... (bQQsted hybrid)
bQQsted hybrid what's up with your car do you still have it. I seen it at battle of imports parked in june.
Have you ever ran or dyno it after you got it running
Old Nov 5, 2002 | 03:14 PM
KoRE's Avatar
K i'll try it i'm only using 450's thoguh.... how do i hook up this injector drive? i couldn't find any instructions on the efi website i got everything else thoguh... and i hook up the 3 bar on the Intake manifold then connect the new harnnes to it right?
tak209
Jan 30, 2013 12:37 PM
foreverwefall
33
Nov 18, 2006 04:35 PM
93turbotegSAV
Sep 28, 2006 08:44 PM
revhigh96
Jun 8, 2003 08:56 PM
mikelcrx
Jul 6, 2002 10:20 PM
