Ethanol VS. Methanol
Old Nov 2, 2002 | 02:16 PM
hondaswaper's Avatar
Default Ethanol VS. Methanol
besides that fact that one is made from grain and the other from wood.........
what are the differences between the two? performance wise..... tuning wise.....
just wondering.......
Old Nov 2, 2002 | 04:22 PM
*Boostwerks*'s Avatar
Default Re: Ethanol VS. Methanol (hondaswaper)
Ethanol sucks.....Methanol is better.
Old Nov 2, 2002 | 04:51 PM
Trac226's Avatar
Default Re: Ethanol VS. Methanol (Bryson)
Doesn't directly answer ure question, just info...Ethanol, as an additive, burns with a higher fuel effeciency than MTBE when in used in reg gasoline. It's not necessarily cleaner burning, but its much easier to clean ethanol up in the environment than it is with MTBE
Old Nov 2, 2002 | 05:33 PM
redcxhatch's Avatar
Default Re: Ethanol VS. Methanol (Trac226)
Methanol has 9800 BTU/LB and 6.4:1 AF ratio and Ethanol has 12,800 BTU/LB and 9.0:1 AF ratio. Ethanol is also almost a pound heavier per gallon.
Old Nov 3, 2002 | 01:11 PM
Default Re: Ethanol VS. Methanol (redcxhatch)
^ thanks for the INFO............
NirVTEC
48
Oct 22, 2011 03:34 PM
RnR EVO 8
May 21, 2008 07:22 AM
Lissav
Audio / Security / Video
Jun 9, 2006 10:48 PM
