went to the track and got some shitty times agian.....
00 itr
drag kit
stock internals/cr
6.6psi (.45bar)
vafc/310's/8:1fmu
60mm N1
running 15x7 kosei's k1's w/yoko A032R@15psi
last time on dyno 241whp/169tq @.45bar
had some traction issues..
r/t 1.060 yea i know..ZZZZZZZZ
60' 2.280
330 6.060
1/8 9.087
mph 84.34
1000 11.666
1/4 13.833
mph 105.52
was hoping for at least mid 13's. this is my second time at the track with the yoko's, im still trying to get use to launching them properly.
least i got a decent mph....
drag kit
stock internals/cr
6.6psi (.45bar)
vafc/310's/8:1fmu
60mm N1
60' 2.280
330 6.060
1/8 9.087
mph 84.34
1000 11.666
1/4 13.833
mph 105.52
New User
Re: went to the track and got some shitty times agian..... (Arturbo)
Hmmm i went 13.81 @ 102.8 on shitty 520 treadwear 14" steelies with 185/65/14 "Premium Touring" maypops...
105 should be EASY mid/low 13's.
Gotta learn to heat up the Yok's and also when to feather the throttle for the second gear BURRRRRNNNNN if you car does anything like mine when the boost hits in first/second
That's my guesstimate.
Re: went to the track and got some shitty times agian..... (1.8TypeR)
Nohing at all to be upset over with only approx 7psi and street tires and i'm sure it was cold which did not help traction but your mph was helped by the cool air more HP! Easy low to mid 13's. Weight?
Re: went to the track and got some shitty times agian..... (Boostfed)
weight? hrm let see, stock car weight,,,2700lbs with me....around 220lbs..so around 2920lbs i guess.
the hp numbers are good for that set up for sure, that trap speed will easliy get you into low 13's, **** when i was having problems with my car while tuning the nitrous i cracked a 13.3 at 101 with big time traction issues.
Re: went to the track and got some shitty times agian..... (tonydatyga)
101 wat?
i am going to mc right now. there are a few py R's at mc.
Smarter than you
those are pretty good times. on BFG's I cut a 13.3 @ 104. your mph is there, u just need more traction.
Re: went to the track and got some shitty times agian..... (DIRep972)
I ran a 13.5 @ 108MPH in my Turbo ITR. Those #'s actually look about right for the power output. My run was with about 40 more HP and 30 more ft. Lbs and a bad clutch...
Not bad though.
M
Not bad though.
M
Re: went to the track and got some shitty times agian..... (01ITR#700)
my friend got a civic coupe with stock b16a and with a used drag kit he hit 12.6... like to know more im thanks.
u need some slicks or at least street slicks,
at 6psi I went 13.5@105
at 7psi I went 13.1@108
at 8psi I went 12.7@111
at 9psi I went 12.8@115
stock R motor
dragIII, 8:1fmu, 255 lph in-tank, RC 310cc, 2.5"cat, cat back N1, launching between 4k-5k
stock R motor
1 Post
I think there are 3. I'm talking about the one that's in the auto tech shop all the time. AT 101 if I'm not mistaken. Big asian guy. That you?
yea thats me...
