car doing something weird...help please...
Old Nov 3, 2002 | 04:50 PM
HondaCutter's Avatar
Default car doing something weird...help please...
When I get on it, usually when I have full boost, the tachometer goes crazy, jumping from like 2 to 7 to 5 and all over the place. the engine doesn't always move with the RPMs however. I'm stumped, the clutch is fine, it still grabs like a bitch, I've only had the engine with the turbo and clutch for month or two. I realized something was wrong when I was getting pushed by a b16'd civic. that's when I looked down and saw the mess.
here's my setup, if it helps.
97 ls motor w/ gsr tranny
drag turbo, @ 5psi
ACT extreme clutch
thats about it, I was thinking it could be the map bypass, so as soon as the car cools down, I'm gonna go check it. but wouldn't I just get a fuel cut?
any help is appreciated, thanks in advance.
Old Nov 3, 2002 | 05:00 PM
speedworks's Avatar
Default Re: car doing something weird...help please... (HondaCutter)
check your connection on the ignitor, if they are loose it will cause the tach to jump eraticly as you described.
Old Nov 3, 2002 | 05:02 PM
Default Re: car doing something weird...help please... (speedworks)
i hate to sound like an idiot, but where can I find the ignitor?
Old Nov 3, 2002 | 05:21 PM
also, would a bad ignitor cause a power loss?
Old Nov 3, 2002 | 06:02 PM
bump
Old Nov 4, 2002 | 09:16 AM
bump
Old Nov 4, 2002 | 10:54 AM
RGAZ's Avatar
New User
Ignitor is inside the distributor. Wires are connected on the outside white connector and inside with 4 clips. A loose wire will throw a code. May want to consider replacing the ignitior just in case.
Yes, a bad ignitor will cause small misses and low arc voltage and the engine will be slower.
Randy
Old Nov 4, 2002 | 11:49 AM
Default Re: car doing something weird...help please... (RGAZ)
would it misfire if my plug wires were bad?
Old Nov 4, 2002 | 12:59 PM
bumpity bump
B18cHatch4u
12
Oct 1, 2006 08:01 AM
EF-Honda91
Jul 12, 2006 10:41 PM
EF-Honda91
Jul 8, 2006 12:48 AM
coupe_hybrid
Feb 17, 2006 07:59 PM
