How do I know if it has gone bad?
Old Feb 10, 2003 | 05:42 PM
Daniel's Avatar
Default How do I know if it has gone bad?
How would I know if my MAP sensor has gone to ****? I can go WOT at full boost just fine, but once I hit VTEC, I get a CEL 03 for "an open/short in the MAP sensor or a bad MAP sensor." A local shop told me it's probably the blue box I'm using, but a grip of people elsewhere said I'll need a new sensor. I trust you guys more.
thanx
Old Feb 10, 2003 | 07:11 PM
Daniel's Avatar
Default Re: How do I know if it has gone bad? (Daniel)
hello
Old Feb 10, 2003 | 08:44 PM
Chrome Pipes's Avatar
As far as I know if the stock map sees boost it will throw a code. I put on a missing link with my turbo kit and never threw a code with 11 psi. If you didn't install check valves or anything like that to trick the map into not seeing boost it would probably throw a code.
Old Feb 10, 2003 | 08:52 PM
Daniel's Avatar
Default Re: How do I know if it has gone bad? (Chrome Pipes)
I'm using the blue box, so maybe it's a bad blue box? But I don't understand why I only throw a code when I crossover into VTEC. Other than that, I can make full boost just fine, but I HAVE to stay out of vtec lest I want to throw a CEL 3.
[Modified by Daniel, 5:53 AM 2/11/2003]
Old Feb 11, 2003 | 10:04 AM
Daniel's Avatar
hello
Old Feb 11, 2003 | 10:30 AM
silverEH2's Avatar
just get a missing link
Old Feb 11, 2003 | 11:17 AM
Daniel's Avatar
Default Re: How do I know if it has gone bad? (silverEH2)
so you don't think the MAP sensor has gone bad then?
Old Feb 11, 2003 | 11:19 AM
LsTurbo91's Avatar
there are ways to test the map sensor depends on the car/yr. Get or borrow a helms manual if you want to test it.
teg_95
Apr 28, 2009 07:19 PM
eggie75
Apr 7, 2008 01:40 PM
kell211
Oct 7, 2003 05:39 PM
platinum00
Jul 25, 2003 09:16 AM
Sivik
Feb 4, 2003 01:42 PM
