Tunning turbo kit with pyrometer
Old Feb 10, 2003 | 08:48 AM
civic1990si's Avatar
Default Tunning turbo kit with pyrometer
Hi,
I would like to know what do you think about tunning a turbo projet of 8 psi with a pyrometer???
Thanks a lot
Old Feb 10, 2003 | 01:21 PM
Default Re: Tunning turbo kit with pyrometer (civic1990si)
bump
Old Feb 10, 2003 | 01:25 PM
Tinker219's Avatar
wtf is a pyrometer? same thing as exhaust gas temperature? if it is, then that can be a big help in tuning....
Old Feb 10, 2003 | 01:41 PM
Default Re: Tunning turbo kit with pyrometer (Tinker219)
yes a EGT.. because i have a A/F but it's a **** for tunning. so i am wondering to install a EGT. Do you think i will be correct for 8 psi on a D16A6 with stock internal?
Old Feb 10, 2003 | 01:43 PM
lugnuts's Avatar
it will help, but your ignition timing will affect EGT as much and sometimes more than your a/f ratio.
best bet is to take a trip to your local dyno with wide band O2
Old Feb 10, 2003 | 01:47 PM
Default Re: Tunning turbo kit with pyrometer (lugnuts)
wide band o2.
Why the EGT will affect my timing???
Old Feb 10, 2003 | 02:22 PM
BudaKai's Avatar
Easy:
WB is essential for tuning.
Retard timing too much = Temps climb higher and higher.
Advance too much = Detonation and the deadly ping, which causes temps to go up faster.
Old Feb 10, 2003 | 07:35 PM
Default Re: Tunning turbo kit with pyrometer (BudaKai)
ok so thank a lot all.
I think i will go for the EGT and some dyno session
Old Feb 11, 2003 | 03:06 AM
Joseph Davis's Avatar
SDS-EFI has a really good article on how to tune for best power with an EGT.
Old Feb 11, 2003 | 03:57 AM
Default Re: Tunning turbo kit with pyrometer (J. Davis)
oh yeah....
can you give me the link please???
Old Feb 11, 2003 | 08:30 AM
ttt
Old Feb 11, 2003 | 08:44 AM
EE_Chris's Avatar
Tuning via EGT
4potnick
Engine Management and Tuning
Apr 7, 2009 09:35 PM
all_out_jdm
May 21, 2005 04:23 AM
sho1
Jun 3, 2004 05:28 PM
Screaminz28
Feb 12, 2003 02:15 PM
smoothludey2
Sep 6, 2001 06:53 PM
