How much whp should this setup make?
Old Feb 10, 2003 | 10:35 AM
MIKES's Avatar
Default How much whp should this setup make?
B16A 1st Gen head mildly ported
JG Intake manifold
64mm throttle body
2001 GSR cams
AEM cam gears
LS bottom end freshened up ( 9.5 to 1 comp)
Eagle rods
SRP pistons .20 over
STR blockguard
TypeR oil pump
92 GSR cable tranny tranny
Stock flywheel lightened and balanced to 13 pounds
Clutch Masters Stage 3 clutch & pressure plate
Spark manifold
T3 60-1 turbo with stage3 wheel .63 exhaust housing
2 1/2" intercooler piping
Spearco front mount 26 x 8 x 3.5
HKS blowoff
Tial 35 mm wastegate
B&M adjustable fuel reg
255 Walbro pump
720cc
Zdyne Gold ecu
Taylor wires
How much whp would this setup make at 12psi on 94 octane Sunoco pump gas, and what would it make at 20psi on race gas? I have a bet with a guy in a Mustang that made 440whp that this setup would give him a run for his money rolling in 2nd to 4th gear. Both cars on a sticky tire and race fuel.
His 94 Mustang wieghs 3750 with driver
My Integra wieghs 2840 with me in it
Old Feb 10, 2003 | 10:50 AM
boosted hybrid's Avatar
Default Re: How much whp should this setup make? (MIKES)
On 12psi probably around 300-350whp. At 20psi probably around 400-450whp.
Old Feb 10, 2003 | 10:54 AM
camp1320.com's Avatar
Default Re: How much whp should this setup make? (boosted hybrid)
12 psi .??? but with a similar set up i have seen 485hp at 20psi with a hondata. now the Zdyne is similar to hondata so...Good luck post the dyno number
Old Feb 10, 2003 | 12:22 PM
MIKES's Avatar
Default Re: How much whp should this setup make? (camp1320.com)
Thats all I wanted to hear. His guy is so thick headed, he can't look past the Ford emblem. He is gonna be stunned, because he can't even power shift his car without misshifting (no pun intended). All I have to say is you better drive it like you stole it.
Old Feb 10, 2003 | 12:28 PM
I Like Boost's Avatar
ya that will diffrently be able to shut him up. just throw in some race gas and turn the boost up and you should be able to take him from a roll no problem. good luck!
Old Feb 10, 2003 | 01:04 PM
BudaKai's Avatar
Default Re: How much whp should this setup make? (IMPULSE B18C-T)
Post vids please.
Old Feb 10, 2003 | 01:37 PM
blufke's Avatar
Default Re: How much whp should this setup make? (BudaKai)
Post vids please.
yes please. damnit i cant wait till im boosting.
Old Feb 10, 2003 | 02:04 PM
DIRep972's Avatar
Smarter than you
set up looks great mikes but if its not too late I would sleeve it.
on race gas u should have plenty of power to see that mustang in ur rearview.
91DA-C
Jun 7, 2010 01:04 PM
lsdb1
Aug 4, 2009 08:56 AM
crazyimport
Aug 2, 2005 09:18 PM
MIKES
Jun 27, 2003 05:15 AM
MIKES
Nov 7, 2002 03:31 PM
