Converting from obdo-obd1
Old Feb 7, 2003 | 06:45 AM
FOrSfEd's Avatar
Default Converting from obdo-obd1
I know I will need a new distributer, right know I can't seem to think clearly prob cause I'm tired as hell but anyway what else will I need to make the conversion over. I already have a p28 ecu. Also will I still beable to use the resistor box, without wiring in anything. I do realze these are easy questions but when you are going on no sleep, sometimes you need help.
Thanks
[Modified by ALLsh0w, 7:47 AM 2/7/2003]
Old Feb 7, 2003 | 07:19 AM
V3locity's Avatar
Default Re: Converting from obdo-obd1 (ALLsh0w)
Really just a obd0 to obd1 conversion harness and a few OBD1 plugs. Yes, you will need an OBD1 dizzy too. A friend of mine makes harnesses, so let me know if you need one.
Old Feb 7, 2003 | 07:21 AM
FOrSfEd's Avatar
Default Re: Converting from obdo-obd1 (illdezignzls)
Thanks alot,
Lee
Old Feb 7, 2003 | 08:34 AM
Doodoo's Avatar
You need a 4 wire O2 as well. I found last night after messing with my distributor that you can remove the 2 prong plug instead of cutting it. I did not know that.
Yes you can still use the resister box and stock injectors
[Modified by Doodoo, 11:35 AM 2/7/2003]
Old Feb 7, 2003 | 08:38 AM
inspyral's Avatar
https://honda-tech.com/zerothread?id=390600
Old Feb 7, 2003 | 08:44 AM
FOrSfEd's Avatar
Default Re: Converting from obdo-obd1 (inspyral)
Thanks for the extra info. I 've ordered the harness and everything so I am good to so it seems.
Lee
90civicstdgold
Jul 7, 2011 03:20 PM
sliiiiced
Jul 7, 2010 07:50 PM
one-cam
Jun 21, 2008 08:40 PM
aXhatch
Sep 12, 2006 06:26 PM
t . b o z
Jul 12, 2004 06:08 PM
