What times do you think I should pull with my setup?
Its a B18b motor in a 96 civic coupe ex with a gutted interior 2 seats...body kit...t3/t4 turbo intercooled with a Fields AFC...Chipped OBd1 ecu...Fuel Pressure Reg...6.5-7 psi...Act 6puck clutch kit with HD pressure plate...BBK fuel pump...how much do you think i can boost and what times do you think i can make...I wanna get atleast into the low 12.7-13.1 rangish...thanks
Re: What times do you think I should pull with my setup? (B18PoweredCivic)
Re: What times do you think I should pull with my setup? (nsxmatt)
Before i got the fields...the shop that does my work chipped the ecu with some program that the use...it dropped .4 of a sec on my 1/4 ets with a stock LS...I was doing 15.5
go back to a stock ecu. the chip is probably a allmotor one, that leans out the fuel and advances timing. which is a nono in a boosted app.
depends on how you race. but i think 13's
Chipped ECU? Why is it chipped?
If it's chipped it's more likely gonna make your motor go boom.
Boost + advanced timing and lean fuel conditions = boom.
ohh and yeah your looking at low 13's
lilxvtecxpwr
12-03-2002 08:01 AM
