What timing to run?
Old Feb 7, 2003 | 05:25 AM
TurboDC4's Avatar
Default What timing to run?
Well I dont have the money right now for hondata. Im planning on running an 8.1 Fmu inline pump and 310's. How much timing should i run to be safe? Boosting around 7 pounds.
Old Feb 7, 2003 | 07:21 AM
TeStUdO's Avatar
Default Re: What timing to run? (SpoonDC4)
about .5 degrees for every pound of boost is a safe setup
Old Feb 7, 2003 | 08:09 AM
TurboDC4's Avatar
Default Re: What timing to run? (00si5)
Is that retard .5 for every pound?
Old Feb 7, 2003 | 08:11 AM
bottlefedb18c1's Avatar
i run a .5 retard per psi of boost with 310cc on a b18c1 with a base of 16.5 degress
Old Feb 7, 2003 | 10:20 AM
b16ahybrid's Avatar
yep..
since i have no btm to adjust my timing i just run 12 degree's all the time until i get a btm.....sucks for power but gets the job done
Old Feb 7, 2003 | 02:29 PM
Diego Boost's Avatar
Default Re: What timing to run? (b16ahybrid)
I would suggest at least running a BTM untill you can get a new ECU or somthing, you gotta be damn careful with your timing man, my engine got destroyed after only 1 week of driving with the turbo on because the timing was off and I was detonating.
Go fast and be safe,
99GSRT
civic_std
Jan 12, 2006 09:54 AM
B_1_8_hatch
Jul 28, 2003 01:33 PM
wzcb08
May 19, 2003 07:47 PM
hybrid901
Sep 11, 2002 05:33 PM
no show all go
May 30, 2002 07:51 PM
