B18C owners... what size turbo are you running, and how do you like it?
What are the specs on your turbo?
How many lbs/bars of boost are you running?
Is your block built? (if so, give details)
Dyno'd? #'s?
Is anyone running higher compresision (11:1 or so) and running low boost? How do you like it?
Looking for any input on which turbo to get for my 10.8:1 GS-R.
[Modified by 94TealGSR, 12:19 AM 2/8/2003]
[Modified by 94TealGSR, 1:14 AM 2/8/2003]
Dyno'd? #'s?
Re: B18C owners... what size turbo are you running, and how do you like it? (94TealGSR)
Turbo = 62-1
Boost= 14psi on pump gas.
Block Built = Yes
Compression = 10.2:1, 81mm Pistons
Like it ? = Hell Yeah!
Before we tell you what turbo, you have to tell us how much horsepower you want to make....
Edit-
Power - 426WHP @ 21psi
[Modified by ekb18c, 9:13 PM 2/7/2003]
Block Built = Yes
Edit-
Re: B18C owners... what size turbo are you running, and how do you like it? (ekb18c)
Re: B18C owners... what size turbo are you running, and how do you like it? (evoeone)
Not looking to build the block at all (I'm running USD ITR Pistons and a blockguard, otherwise stock B18C1). I don't have a set # in mind for horsepower, but I'm obviously looking to get the most out of my setup. It will be a daily driven car. I'm looking for something that spools decently fast, and still gets good flow at 8000rpms.
I am looking to run between 5-7lbs of boost(.3-.5bar). Anything more than that would entail more work than I'd like to do at this point, and if I end up wanting to run more in the future I'll get a diff. turbo. Thanks for the input.
make sure you get it tuned really well, your at 10.84 roughly to 1 CR. im trying to pic a turbo for my gsr too, so keep it coming boosted gsr people.
Re: B18C owners... what size turbo are you running, and how do you like it? (blufke)
sc60 here 60 trim, .63 ar, 76 turbine trim
Built block- yes
power- ??? havent ran it yet
boost- ????????
Built block- yes
boost- ????????
Re: B18C owners... what size turbo are you running, and how do you like it? (tSuperbike69)
turbo: precision pt67 gtq
built block: yes cr:10:1
powa: very little NA
boost: not runing yet
HT's Biggest Loser
Turbo = Turbonetics T61
Boost = 17psi
Block = GE Sleeves, 81mm Bore
CR= 9:1
Power= Check Signature = Fun
[Modified by SIXTYdashONE, 6:18 AM 2/8/2003]
Boost = 17psi
CR= 9:1
Re: B18C owners... what size turbo are you running, and how do you like it? (SIXTYdashONE)
just curious u know , just ur nickname says "60-1"
Bulldogg83
10-15-2003 11:06 PM
