whats the difference between a Ls Block and Gsr block...
Old Feb 10, 2003 | 06:49 PM
justmotor13's Avatar
Default whats the difference between a Ls Block and Gsr block...
and which one would be better for a turbo setup, i know compression and such is a little different between both, i've heard the LS is known as a good turbo block, but which one can handle and put out overall more power?
ekb18c's Avatar
Default Re: whats the difference between a Ls Block and Gsr block... (crx31286)
more power= gsr.
Old Feb 10, 2003 | 07:36 PM
thrty8street's Avatar
agree go with the GSR. if money is an issue then the LS is the alternative.
Old Feb 10, 2003 | 10:17 PM
BoostedSi's Avatar
Gsr block has oil squirters and a ls block doesnt. Also has oil feed at the top of the block for the head.
Umm...i dont see how an ls block would be better for turbo. Gsr has more power stock and will have more power boosted. Go with the gsr block.
Old Feb 10, 2003 | 10:27 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: whats the difference between a Ls Block and Gsr block... (BoostedSi)
go gsr if the funds are there!!!
Old Feb 11, 2003 | 09:07 AM
killerTeg's Avatar
New User
Default Re: whats the difference between a Ls Block and Gsr block... (MotorMatrix.com)
Correct me if I am wrong, but doesn't the gsr block have a slightly slower piston speed, so if you are turbo and VTEC it would be better? I guess if you are not going VTEC, it would not be as much of a big deal.
-Keith
Old Feb 11, 2003 | 09:26 AM
luckypon7's Avatar
Default Re: whats the difference between a Ls Block and Gsr block... (killerTeg)
here what i know LS has stronger block with more torgue ideal for running turbo some say with gsr some like the vtec can create more power with little boost. if i'm missing something or wrong correct me.
Old Feb 11, 2003 | 09:47 AM
b18bturbo's Avatar
Default Re: whats the difference between a Ls Block and Gsr block... (luckypon7)
the main differences are mentioned above.
THE GSR block has oil squirtes, oil feed for vtec on deck of block. As well as crank girdle deeper oil pan to handle the girdle.
The LS block has no squirters no oil passages for vtec no crank girdle nothing.. its 2 bolt mains just like GSR fairly strong.
Old Feb 13, 2003 | 06:51 PM
andlude's Avatar
go with the gsr block but not until u get some damn rims and get rid of those dinner plates.....haha damn you jeff
Old Feb 13, 2003 | 07:03 PM
silverkorn's Avatar
the GSR block has a C after the 18 and the LS block has an A or B after the 18
but seriously, the blocks are pretty much the same except what everyone has covered here that the GSR block was made for the VTEC head while the LS block wasnt.
most people go with a LS block for boost mainly for the fact that the engine is cheaper to get and install and also the stock compression ratio is lower. but as for cylinder strength im pretty sure they both are the same.
Old Feb 13, 2003 | 07:04 PM
DefiantGSR's Avatar
-Keith
b18b has lower rod ratio...meaning the gsr has faster piston speeds from TDC..i wouldn't doubt from BDC either.
Old Feb 13, 2003 | 07:29 PM
AlphaKennyWun's Avatar
Default Re: whats the difference between a Ls Block and Gsr block... (DefiantGSR)
are the cranks the same?
Old Feb 13, 2003 | 07:56 PM
CzanSOHC's Avatar
Default Re: whats the difference between a Ls Block and Gsr block... (S03Burner)
No.
Old Feb 13, 2003 | 08:27 PM
Stu's Avatar
Stu
New User
Default Re: whats the difference between a Ls Block and Gsr block... (CzanSOHC)
Doesn't the LS ahve slightly larger displacement. Like 1780cc compared to 1801cc or something?
Old Feb 13, 2003 | 09:00 PM
miller's Avatar
Default Re: whats the difference between a Ls Block and Gsr block... (Stu)
the ls actually has slower piston speeds, the deck height is different also, the ls actually has a taller deck. ( not by much). i see no problems with building an ls over a gsr.... if its done the right way. gsr's cost way to much for some people and why pay $600 or even $700 for a gsr bottom end , when you can buy a complete ls long block for like $200.
ABCVTEC
14
Nov 15, 2006 08:59 AM
russianswty
Oct 17, 2006 03:09 PM
marcussmith26
Dec 5, 2005 05:28 PM
jamal-188
Apr 29, 2002 05:40 AM
