Getting so close...I can't wait to get this puppy back on the road...
Action 2MD clutch, fully endorsed by http://www.ks-motorsports.com
B18B1 with some B20 cam lovin..
Damn the downpipe is going to be ... fun.
Re: Getting so close...I can't wait to get this puppy back on the road... (Hatchblack)
What are those big steel braided lines for? I can see the feed for the turbo comes directly off of the oil pump.
Are those other ones water lines?
Sonny
Re: Getting so close...I can't wait to get this puppy back on the road... (Sonny)
um not to be a dick, But looks to my your clutch disk is on the wrong way. That flat side should face the flywheel, flip it around and you should be good. Lates
Re: Getting so close...I can't wait to get this puppy back on the road... (InfamousRS)
I'm sure the clutch disk was turned back around, bc the disk doesn't fit that way... at least it didn't on mine.
I just put the 2md on my Integra last week and it grabs great. I definately like it, but you have to be very good about not undergassing the car or the whole car shakes if you do. The pedal weight isn't heavy at all to me. Alot heavier than stock, but nothing most people couldn't handle or get used to.
Re: Getting so close...I can't wait to get this puppy back on the road... (HybridcivicLS-T)
Yeah, looks like a remote oil cooler. The 2MD is a great clutch.....I love it!!! What else do you have left to do Hatchblack??
They're right Sonny, those lines are for the oil cooler. What I did was use short hoses about 1' long to attach to the adapter, and then I attached the long lines from the oil cooler to these. It's almost impossible to remove/attach the lines directly to the sandwich adapter when it's on the motor.
No, it's a stock longblock, but I got the b20 cams for free (thanks Nick!) and I *think* they have a tiny bit more lift than b18b cams. I could be wrong, but either way I got newer cams that the originals. (if anybody needs a set of 95 b18b cams lemme know ).
It's a stock longblock other than that. I'm behind the power curve...if I had swapped motors back when I made lots of money, then I could be building instead of swapping now
Yeah, the clutch has been turned around since I installed the PP
[Modified by Hatchblack, 4:54 PM 2/8/2003]
How much boost do you plan on running on that setup?
I know what you mean, I'm soo anxious to get my new longblock in my car...damn the cold weather! soon enough though
Re: Getting so close...I can't wait to get this puppy back on the road... (SpoolinLS)
I'm going to follow Direp's example and run in the neighborhood of 12 psi, maybe a bit more at the track.
Almost...allllmost....drove it last night, was fun even in limp mode
Not real happy with my upper IC pipe and obviously the valve cover has a long way to go, waiting on a replacement so I can polish this one when I feel like it. At this rate, that should be about 2 years from now.
Re: Getting so close...I can't wait to get this puppy back on the road... (Sleepin')
STP
Those and Wix are both good but apparently nobody makes a filter wrench that fix the Wix except Napa has some plastic one...I bought it and that POS was worn out after ONE USE!!!
Re: Getting so close...I can't wait to get this puppy back on the road... (TurbothisLS)
How did you get that fuel pressure guage to angle like that? what kinda fitting are you using?
S2k Hybrid
15
01-02-2007 05:05 PM
slowazzhatch
27
08-03-2003 08:58 PM
