ring seal in 35 mm tial wastegate
Hey guys. I am in dire need of a ring seal for a 35 mm tial wastegate. I heard it is also called a "fire ring." I don't know what thats all about. The thing i am looking for is metal ring under the wastegate. Any help would be awesome of anybody selling one, or where i can find one for cheap. THanks.
Re: ring seal in 35 mm tial wastegate (dpreludesi)
The fire ring is part of a gasket like this one:
which can be purchased here: http://www.roadraceengineering.com/f...andgaskets.htm. If you're refering to the metal ring that inserts in the bottom of the tial, there's a couple of tial venders here on the board: b18bturbo, ekb18c, importparts.com,.. who could probably help you out.
I dont use gaskets, and between the manifold, and elbow, elbow and wastegate, and wastegate and downpipe. I have no leaks well atleast i cant hear any, nor see any exhaust. Stan told me about this, cuz i was looking for the firering too. so if the flanges are perfectly flat, try using no gasket.
1 Post
Re: ring seal in 35 mm tial wastegate (Brad)
i think he might be talking about the ring that sits in the WG that you pop on and off from the bottom port...Im sure someone on here can order it for you?
Re: ring seal in 35 mm tial wastegate (Cramerox)
I have a ton of those in stock if you need one. Don't even bother with the ones w/o the fire ring, they won't last.
