how big of a shot to run???
Old Feb 10, 2003 | 09:39 AM
Boostless97Lude
Guest
Posts: n/a
Default how big of a shot to run???
i was thuning of running nitrous on top of my turbo setup, but not sure how big of a shot i should go with, anyone got an ideas?
Old Feb 10, 2003 | 10:48 AM
camp1320.com's Avatar
Default Re: how big of a shot to run??? (Boosted97Lude)
usaully or 40-60 shot would be great to spool up the turbo depending on the size you have. and also extra charge of cold air for the top end use is great. If its a stock motor ... GOOD LUCK you can use dry kit with the proper fuel managementand upgraded injectors if not, you can go with a wet system to compensate for the extra fuel you will need
Old Feb 10, 2003 | 11:32 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: how big of a shot to run??? (camp1320.com)
i was thinking of a direct port kit. spool up time is not the problem, top end is where i lack the most. i was wanting like a ..... 75 wet, direct port shot
Old Feb 10, 2003 | 11:35 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Is your motor built if it is you can do it. I would run about a 50-60
Old Feb 10, 2003 | 12:54 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: how big of a shot to run??? (HybridcivicLS-T)
oh yeah, it's built.... just about anything that could be done, was
Old Feb 10, 2003 | 01:02 PM
T-sohctec's Avatar
Juice it! I think that would be a great setup.
Built
turbo
juiced
lude.
you say you are lacking up top...
just out of curiosity what MPH do you run in the 1/4?
or is this just a seat of your pants thing.
Old Feb 10, 2003 | 01:06 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: how big of a shot to run??? (T-sohctec)
Built
turbo
juiced
lude.
it's just a seat oy my pants thing.... you know, how when it feels like it stops pullin.. anyways, i am currently only runnin 7psi, i do not yet have proper fuel management, but my AEM EMS should be here tomorrow, and i also have some crower stage 2T cams that i have not yet installed, so maybe that'll help some, but regardless, i still want that juics
Old Feb 10, 2003 | 06:03 PM
Boostless97Lude
Guest
Posts: n/a
ttt
Old Feb 10, 2003 | 06:12 PM
rOby's Avatar
well, the smalles dp shot is a 80. the only way to get around this is to have a seperate regulator adjusting the pressure after the fuel t for just the n20.
if u need some n20 parts let me know...i got some cheap good luck on setup..
Old Feb 10, 2003 | 06:17 PM
Boostless97Lude
Guest
Posts: n/a
the NX kit i want is adjustable from 50hp up to 200hp, so, like a 75 shot with proper tuning should be safe, right?
Old Feb 11, 2003 | 09:10 AM
Boostless97Lude
Guest
Posts: n/a
bump
mightyjoecivic
43
May 3, 2007 10:38 AM
QCKGSR
Oct 13, 2005 07:20 AM
NirVTEC
Mar 1, 2004 03:33 PM
BlackB18CTeg
Sep 14, 2003 04:43 AM
thehondaguru
Oct 17, 2002 11:39 PM
