I think I'm in limp mode!
Old Feb 7, 2003 | 03:31 PM
ModAddict's Avatar
Default I think I'm in limp mode! Please help.....
CEL is on and @ 4200 rpm, the engine cuts out. I tried to pull the code with the paper clip, but the CEL stays solid. The ECU seams to be bzzzzzzzing when the engine is on.
Do I need to pull the battery cable before I can pull the CEL code?
[Modified by ModAddict, 7:32 PM 2/7/2003]
[Modified by ModAddict, 7:39 PM 2/7/2003]
Old Feb 7, 2003 | 03:51 PM
94TealGSR's Avatar
Default Re: I think I'm in limp mode! Please help..... (ModAddict)
Limp mode sounds like a personal problem.
What method exactly are you using to get the code? Maybe you're doin it wrong?
Old Feb 7, 2003 | 03:54 PM
Daniel's Avatar
yeah, how are you pulling it? when i get a CEL, i turn off the motor, jump the harness thing with a paperclip, and then turn the ignition to the II spot, i think it is. it's the one that turns on everything but the engine. the CEL will blink then if you really do have a code.
Old Feb 7, 2003 | 04:03 PM
ModAddict's Avatar
I've tried with the engine running and with the key on ign w/o engine running. The jumper is in the small blue connector out of the green rubber boot. NO Blink blink....the light stays solid.
Old Feb 7, 2003 | 04:09 PM
genop's Avatar
Have you tried pulling the battery cable?? Might be as simple as that...
Old Feb 7, 2003 | 04:15 PM
T-sohctec's Avatar
Default Re: I think I'm in limp mode! Please help..... (genop)
Im just trying to think what the hell could be wrong that would make your car do that.
hmmm.... ?
good luck!
Old Feb 7, 2003 | 04:19 PM
PrecisionH23a's Avatar
I hope that helps out your limp problems.... gixxers always help me out
I had the same problem on my car a few months ago, i would drive it for a little while and the CEL would come on. When i shut the car down the CEL would go away and when i tried pulling the code the SRS light just flashed over and over and over and over times 100 more times again without throwing a code. When i installed my hondata it cured the problem though. Does the CEL light come on once you hit boost by any chance? It could be something to do with your map sensor... Try the batter trick listed above.
[Modified by GudeH23a, 8:22 PM 2/7/2003]
Old Feb 7, 2003 | 04:31 PM
ModAddict's Avatar
Default Re: I think I'm in limp mode! Please help..... (GudeH23a)
What were we talkin about...........Oh yeah......WOW she is SMOKIN!
I pulled the battery cable and tried again. No blink, blink. CEL is on at all times. I have Hondata.
Old Feb 7, 2003 | 05:00 PM
have you checked all of your hondata connections? Is the car driving differently at all?
Old Feb 7, 2003 | 05:52 PM
ModAddict's Avatar
The Hondata s100 is a small chip inside the ECU. I guess I can pull the ECU and make sure all is good. When the car goes in "limp mode" the ECU retards the timing, loads it up with fuel, and the new rev limit is 4200rpm, so the car barely runs enough for you to limp home or to the dealer (no way!) for repairs.
Old Feb 7, 2003 | 06:41 PM
TurbothisLS's Avatar
LOL
limp problem
Old Feb 7, 2003 | 06:51 PM
ModAddict's Avatar
DING, DING, DING, DING, We have a winner! The s100 chip had worked it's way loose!
And she really is SMOKIN HOT! Thanks for the help!! And thanks for dressin' up the thread!
[Modified by ModAddict, 10:53 PM 2/7/2003]
Old Feb 7, 2003 | 09:11 PM
man, that girl is the ish
Old Feb 8, 2003 | 10:16 AM
so what do i win? im glad you fixed your problem
Old Feb 8, 2003 | 12:53 PM
B18Flip's Avatar
Default Re: I think I'm in limp mode! Please help..... (TurbothisLS)
Dayum
D0kt3r
17
Mar 18, 2016 06:24 PM
chazmuska
Jun 12, 2009 04:09 AM
emanLS
Oct 20, 2003 01:15 PM
Fatty_1775
Jul 20, 2003 10:23 PM
