questions about MSD FPR w/boost and opinions
i want to richen my mixture a little, can i use this part along with my blue box?
What is the ratio on this part? or does it depend on the screw adjustment
Any help is appreciated.
I'm on a budget btw.
[Modified by nd8ch, 11:44 PM 3/3/2003]
Re: questions about MSD FPR w/boost and opinions (nd8ch)
I dont think an fpr will do much. I guess you could try turning the static pressure up a bit.
btw...wut da hell is an fpr w/ boost? da ****....
Re: questions about MSD FPR w/boost and opinions (BoostedSi)
sorry, the FPR w/boost circuitry or whatevers only raises fuel pressure relative to boost. I think its considered a boost dependent FPR, so it does not react to vac.
What is static pressure? is static fuel pressure with the vac line in place or zero vac?
anyone know what the ratio for this regulator is?
what part of this regulator is adjustable?
[Modified by nd8ch, 8:30 PM 3/3/2003]
Fuel Pressure is about 2-10 psi after Boost, After about 1k miles with turbo I think boost killed my
LastGenEK
02-19-2010 01:11 PM
JM Performance
11-28-2001 03:46 PM
