anyone have setting for 370 cc vafc hack
i have a sohc and i put 370-380 red talon injectors in.. and i wanted to know if anyone know some numbers to start with for the hack ..?
come one.. someone has to have tried the vafc hack with other sized injectors.. all i want to know.. is .. what are some of the setting u all tried.. or where do i start.. to get a clean top end.. and not a lugish bottom end
[Modified by havok hybrid, 7:47 AM 2/10/2003]
Can someone help me out.. when i lower the Narr 1k to -10 or lower.. it runs like **** .. wow am i suppose to get to -35 to run the hack.. So .. i have missing link.. should i use it.. if so what should the graphs BE.. PLEASE HELP !!!!! i get CEL out of 2nd gear without missing link and with one check valve.....
I would start at -30 across the board since most people start with -40 with the 450s. Do not use the missing link or ceck valves. You probably won't be able to run more than 8 psi like this. Good luck!
First Gen Man
Dec 25, 2002 12:17 AM
First Gen Man
Dec 24, 2002 08:19 PM
