New Dyno #'s
Old Feb 8, 2003 | 07:54 AM
hybrid901's Avatar
Default New Dyno #'s
Just got back from the dyno and at 18-19psi it put down 372/277. Its totally untuned above 14psi and the graph needs some work. I think I maxing out the 550cc's. I will have my graph scanned when I get home from work and posted.
My setup
b18c1
stock sleeves
blockguard
srp 9:6:1
eagle rods
stock head
skunk intake mani
inline pro manifold
60-1 hifi
3" dp
3" Thermal
550cc
hondata 2b
Old Feb 8, 2003 | 08:01 AM
Smashback's Avatar
Default Re: New Dyno #'s (hybrid901)
Sweet, good job! I'm sure at that HP level you are maxing those 550s...just crank up the fuel pressure a little
Old Feb 8, 2003 | 08:46 AM
avividmemory's Avatar
Default Re: New Dyno #'s (Hatchblack)
nice numbers get that graph up
Old Feb 8, 2003 | 01:21 PM
95c1v1cs1's Avatar
Default Re: New Dyno #'s (SpoolinLS)
Wow. Nice Numbers!! what turbo are you running?
I can't believe you put 19psi on stock sleeves. I think that is crazy. Maybe that is just me.
[Modified by 95c1v1cs1, 10:26 PM 2/8/2003]
Old Feb 8, 2003 | 01:34 PM
400whp@10000rpm's Avatar
Default Re: New Dyno #'s (95c1v1cs1)
alote of people do 20-22 psi whit stock sleeves!
Old Feb 8, 2003 | 01:42 PM
JDMs1eeper's Avatar
those are some great #'s , keep it up and get some tuning for the 18-19psi range so you dont mess them sleevs up
Old Feb 8, 2003 | 01:44 PM
hybrid901's Avatar
Default Re: New Dyno #'s (400whp@10000rpm)
I planned to run 21-22psi but I maxed out the 550's.
Old Feb 8, 2003 | 01:48 PM
b18cTurbo's Avatar
so the 22 psi your sing down how did you made it?
Old Feb 8, 2003 | 02:02 PM
hybrid901's Avatar
Default Re: New Dyno #'s (mikvtec)
I have only ran 22psi at the street races a few times. When I saw how lean it was today I won't be doing that again until I get some larger injectors.
Old Feb 8, 2003 | 03:06 PM
synergy004's Avatar
i was wondering, did you ever post a video of your ride doing a burn out. I saved them because if it is, damn car sounds good.
on me
Old Feb 8, 2003 | 03:27 PM
ProEater's Avatar
impressive
Old Feb 8, 2003 | 04:36 PM
ViperRedCRX's Avatar
Default Re: New Dyno #'s (ProEater)
shoulda seen the way it blazed the tires the first time on the dyno, that was impressive
Old Feb 9, 2003 | 01:19 PM
RyanAutry's Avatar
Default Re: New Dyno #'s (ViperRedCRX)
Awesome numbers.
OT: What are the dimensions of you intercooler? Did you loose your bumper support?
Old Feb 9, 2003 | 05:44 PM
BoostedSi's Avatar
Yea, its just you.. Naw i'm just kidding... I've seen many people running that kind of boost levels on stock sleeves. Its possible
Old Feb 9, 2003 | 06:53 PM
RyanAutry's Avatar
Manifold pressure has nothing to do with how much the stock sleeves will hold. It's all about HP. 375 sounds resonable on stock sleeves.
Old Feb 9, 2003 | 08:55 PM
Reilly's Avatar
good #'s, need bigger injectors saw your other post...
Old Feb 10, 2003 | 01:28 AM
Jdm_Rice_Monster's Avatar
Default Re: New Dyno #'s (Reilly)
Good numbers.
rrace002
32
Nov 9, 2012 04:59 PM
Thomascivicsi
Mar 8, 2010 05:04 PM
Jared
Jun 20, 2004 04:03 PM
pollito
Dec 16, 2003 01:12 PM
WykidEH
Feb 9, 2003 05:13 PM
