Tial 40mm Wastegate, Will it hold 30psi and 650-700hp???
I am a bad person
I have never used tial products before and i dont carry them so I dont know too much about them. Will the 40 mm gate hold 30 psi and 700hp?? I have been using the hks standard gate and its works perfect. I have been on 26psi +nitrous and it doesnt creep at all. Does anyone know if the hks gate since it is 40mm also will fit on the same flange as the tial 40mm?? one more thing, what is the difference int he standard 40mm and the tial HP 40mm?? is it just a stiffer spring?? i see the hp gates start at 15lbs and up where the standard gate goes to 14.5. thanks for any info, you guys can give me. Ive been researching my *** off and cant find concrete info.
[Modified by MotorMatrix.com, 12:30 AM 2/8/2003]
Re: Tial 40mm Wastegate, Will it hold 30psi and 650-700hp??? (MotorMatrix.com)
yep, it will. Also look at a racegate -- its only 42mm and ive seen it control 943 whp.
I am a bad person
Re: Tial 40mm Wastegate, Will it hold 30psi and 650-700hp??? (rOby)
they do make a 46 but the wastegate port on the full-race manifold i have is a 40mm and dont want to chop it or alter it.
worked for me. the turbonetics racegate can't be compared to the tial 40mm. it will outflow it! innovative makes a 42mm that is good to 900+hp.
I am a bad person
Re: Tial 40mm Wastegate, Will it hold 30psi and 650-700hp??? (ninesecteg)
yeah the pro gate from innovative is nice. so the 40mm worked ok for you?? and you are saying the racegate will out flow the tial??
You should have no problem with the Tial ive only heard and seen good things with them.... good luck
Re: Tial 40mm Wastegate, Will it hold 30psi and 650-700hp??? (QCKGSR)
don't get me wrong, the tial w/g's are great, but I couldn't run anyting less then 18psi without creep. this doesn't work out to well when your trying to run 12 psi in first gear and the w/g creeps to 18. get the innovative!
Re: Tial 40mm Wastegate, Will it hold 30psi and 650-700hp??? (b18bturbo)
it wasn't spiking, it would just keep creeping up. it would start at about 14 and creep to 18. I reaaly don't believe you could stick a 8psi spring and expect it to hold a solid 8psi, there is just to much energy for that w/g to bleed off. I was running the jg/hotshot manifold.
With Tial that's the exact case. I put a 14psi spring in and it holds 14psi on the dot. That is why Tial is so great because it is very accurate.
I wasn't a believer of tial at one time till i tried and tested their product.
I put in a 7psi spring and it held at 7psi on the dot.
There might have been other factors that might have caused the creep.
yah but for high h/p motors with higher compression and cams etc. the tial 40mm won't cut it!
MotorMatrix - why are you switching from the HKS??
HT's Biggest Loser
Hey Mike, if i was you, id just get the 46mm, im sure there is soemthing geoff can do about the WG flange.. besides if you want to hold boost with the best of accuracy, i reccomend the tial 46mm.. Cutting and rewelding a 46mm flange shouldnt be that hard anyways, id rather be safe then sorry, you know? good luck.
I am a bad person
Re: Tial 40mm Wastegate, Will it hold 30psi and 650-700hp??? (IMPULSE B18C-T)
and why is that? What proof do you have, everyone i know with the Tial have had no problems.
ninesecteg-my new motor is going to be 9:1 and will have stock type r cams. the tial should work ok. if it doesnt i'll sell it and go back to HKS or go with the T'netics newgen with the v-band.
