My Dyno 19psi
Old Feb 9, 2003 | 06:20 PM
hybrid901's Avatar
Default My Dyno 19psi
I know its been posted under a different thread but I have a few questions. My car hasn't been tuned since 13psi. I'm not sure what the AF was on this run but I believe my 550's maxed out between 6-6.5k. On my other dyno months ago my tq was flat from 6k to 8500. Would leaning out cause tq to fall off but still have hp slowly rise? I'm trying to get teh best run out of this engine before I switch to a sleeved block. Can I install a B&M or AEM fuel regulator and tune my static pressure up from 44psi to 55-60psi and add enough fuel to keep it safe at teh track.
setup-
b18c1
srp 9:6:1
60-1 hifi
hondata 2b
550's
255lph hp pump
Old Feb 9, 2003 | 06:29 PM
rOby's Avatar
Default Re: My Dyno 19psi (hybrid901)
i dont think it was the fuel causing the torque to stop increasing..just my hunch,
nice graph ! im pretty sure you can add some c16 and raise the fuel press and add a marginal amount of safety for track
Old Feb 9, 2003 | 06:32 PM
BudaKai's Avatar
Those poor sleeves . Nice numbers.
Old Feb 9, 2003 | 06:38 PM
ImportReview
Guest
Posts: n/a
Default Re: My Dyno 19psi (BudaKai)
RC 550's will max out with a STOCK fuel pump, at about 380-390 WHP.
Actually, the fuel pump doesn't matter, its all about pressure, if you have it at like 55, which is pretty much the max on a good stock pump, 380 will be the result.
Jeff
Old Feb 9, 2003 | 07:05 PM
Stag 2000's Avatar
Default Re: My Dyno 19psi (ImportReview)
The base pressure on that run was 44psi. I'll get an adjustiable regulator and turn the base pressure up to 55-60psi. Anyone with any guesses why tq drops of like that?
[Modified by Stag 2000, 4:05 AM 2/10/2003]
Old Feb 9, 2003 | 08:16 PM
DIRep972's Avatar
Smarter than you
Josh I think you are definitly leaning out. look at how smooth the torque curve is and then it just drops off and gets squirly where turbo gsr's(especially w/ 60-1's) usually peak and hold flat until around 7500. thats no good u might be getting detonation too.
Old Feb 9, 2003 | 08:21 PM
hybrid901's Avatar
Default Re: My Dyno 19psi (DIRep)
It does look like it could be detonation. How could I tell for sure?
Old Feb 9, 2003 | 08:34 PM
DIRep972's Avatar
Smarter than you
it may not be audible if ur car is really loud, or if u don't know exactly what to listen for. There is a trick i know to check for really really subtle detonation. Get a stud and find somewhere on ur block, preferably where u took out powersteering or AC. have u? put a stud in and put a stethascope on the stud and listen to it.
Old Feb 9, 2003 | 08:43 PM
dmotoguy's Avatar
it looks like it is slightly detonating at higher rpms, how the graph has little peaks and valleys, thats only what ive been told though...
Old Feb 9, 2003 | 09:13 PM
accordfreak's Avatar
Default Re: My Dyno 19psi (dmotoguy)
i thought 550cc injectors are good up to 440hp?
550/5 * 4 = 440
[Modified by accordfreak, 6:13 AM 2/10/2003]
Old Feb 9, 2003 | 11:10 PM
vw-honda-hatches's Avatar
Default Re: My Dyno 19psi (accordfreak)
stock sleeves geez BOY can you give more on your setup? rods? flywheel etc? sorry This car/motor may convinced to go pistons and rods with no GE block. and the turbo set up...
I can add that the top on of the graph seems to be leaning or deatantion for sure. But how are you gonna find out if its detanating with a sethoscope while under load under boost?
[Modified by vw-honda-hatches, 8:14 AM 2/10/2003]
Old Feb 10, 2003 | 05:04 AM
DIRep972's Avatar
Smarter than you
Default Re: My Dyno 19psi (vw-honda-hatches)
its just like when ur at the doctor and the doctor puts a stethascope to ur stomach and he can hear all ur internal organs. same type of thing with a motor, if its detonating u will be able to hear real quiet pings that u can't normally hear. run a vacum line from the stud to the stethascope and stand in a more quiet area.
Old Feb 10, 2003 | 06:03 AM
hybrid901's Avatar
If you have the $$ I would deffinatly sleeve the block. If I would have sleeved the block last year I wouldn't be building another motor again. When I first built this motor I only want 300whp now 370 doesn't feel fast enough.
I'm going to get a fuel regulator and turn the pressure up before I go back to the dyno and see if that helps.
Old Feb 10, 2003 | 06:39 AM
fastludeh22's Avatar
if you have hondata, why are you messing w/a fpr? why dont you just get on a dyno w/wb o2 and tune it. it would be much better to add fuel where you need it, insted of just upping the fuel pressure.
thats why i bought hondata to tune the hell out of it.
just my $.02
Old Feb 10, 2003 | 07:17 AM
hybrid901's Avatar
Default Re: My Dyno 19psi (fastludeh22)
Because I'm pretty sure my injectors are running at 100% duty cycle @ 44psi.
Old Feb 10, 2003 | 12:11 PM
ImportReview
Guest
Posts: n/a
all the mathmatics in the world can't argue against real world facts.
All it shows is that the mathmatics behind calulating WHP for sizes of injectors is not an exact science.
Maybe its 440 BHP>
Turn up your fuel pressure to like 60 PSI, then you will get like 20 more WHP out of it or so.
Jeff
Old Feb 10, 2003 | 12:33 PM
Boo Boo'n's Avatar
how can anything with 370 whp get boring? i know you spin , but i don't think boost will EVER get boring. maybe that's because i don't have it
Old Feb 10, 2003 | 01:01 PM
BudaKai's Avatar
I would add the FPR and see what happens. Your fuel pressure appears to be a very likely canidate, but what's your timing like way up there? I just don't see you running out of fuel. It should be leaning out, but I don't see it running that lean to detonate if you adjusted you timing maps to work with it. It shouldn't even detonate if you can keep everything cool coming in the correct timing would allow you to bure a leaner mixture.
(*Gets flame suit in ready position.* I know it sounds crazy, but it's true.)
Old Feb 10, 2003 | 01:48 PM
lugnuts's Avatar
should have used the dyno's a/f logging capability.
and after you suspected the detonation/lean condition, as in right when the engine was shut off, you should have had someone who knows what to look for check your spark plugs to see what was going on in there. now you know
Old Feb 10, 2003 | 01:52 PM
hybrid901's Avatar
Default Re: My Dyno 19psi (lugnuts)
My timing is set at 17 degrees over 14psi.
Old Feb 10, 2003 | 04:20 PM
lazy bum shaughn's Avatar
Goodness. Run it at the track and take more videos.
Old Feb 10, 2003 | 05:46 PM
scooter's Avatar
Your running that much boost without knowing what your A/F ratio is?? And you are possibly very close to maxing out your injectors?? Damn son, you must want to blow the motor. Seriously, what are you thinking?
Not smart in my opinion.
scott
Old Feb 10, 2003 | 05:48 PM
hybrid901's Avatar
Default Re: My Dyno 19psi (lazy bum shaughn)
I just went out and checked and my timing and the distributor is at 14 degrees so even though the hondata shows 17 degrees does that mean I'm really at 15? Also my fuel pressure at idle is at 42psi. I'm looking at a aeromotive or a aem fuel regulator. Is either better than the other?
Thanks
Old Feb 10, 2003 | 08:19 PM
hybrid901's Avatar
What fuel pressure do I need to run to make 400whp with 550cc injectors?
Old Feb 11, 2003 | 09:58 AM
ImportReview
Guest
Posts: n/a
maybe above 60-65 or so?
with hose ON.
Jeff
