What cc injectors???
Old Feb 9, 2003 | 06:34 PM
95c1v1cs1's Avatar
Default What cc injectors???
I was wondering if i could run 440cc injectors for a max of 375 hp. The price from the 440's to the 500's is a huge jump. Thanks
Old Feb 9, 2003 | 06:35 PM
J2turbo21's Avatar
Default Re: What cc injectors??? (95c1v1cs1)
I think your gonna need more than 440's for 375hp.Whay kind of injectors were you looking for?I knew b18bturbo is having an awesome groupbuy on injectors all the way up to 1000cc.
Old Feb 9, 2003 | 06:57 PM
Anubyss's Avatar
Default Re: What cc injectors??? (J2turbo21)
I think you should just play it safe and go with 720cc injectors if you are looking for that kind of power. You should be able to do it with 550cc injectors but at a higher fuel pressure than stock. I assume you have some sort of fuel management system if you want that kind of power. Why risk leaning out?
Old Feb 9, 2003 | 07:04 PM
Elite Hatch's Avatar
Default Re: What cc injectors??? (Anubyss)
This question is hard to answer..You need to tell us your whole fuel managment setup..I have seen 440s do 375hp but its pushing it.
Old Feb 9, 2003 | 07:11 PM
95c1v1cs1's Avatar
I was looking to get some RC injectors. I Want something that is going to fit in without modifying. If i get 550cc peak and hold injectors, will alls i need is a resistor box to run correctly?
Honestly i was going with the 440s b/c they are cheap(280 shipped) and i won't have to deal with buying a resister box.
So i should definitely should go with more than 440s huh...
Old Feb 9, 2003 | 07:14 PM
95c1v1cs1's Avatar
Default Re: What cc injectors??? (Elite Hatch)
I have a Walboro 255 fuel pump, AEM fuel rail, AEM FPR, Vortec FMU(not installed yet), and fuel gauge, and V-afc.
Old Feb 9, 2003 | 07:52 PM
J2turbo21's Avatar
So your planning on the afc hack.Most people dont get rc's but dsm injectors and a resistor since its the cheapest.If your planning a afc hack then you dont need the FMU.From what i heard fmu's suck a$$ cause of fuel pressures above and beyond 100psi.
Old Feb 9, 2003 | 07:53 PM
Dont do a hack just buy a missing link...and run it that way...thats what i did...I run 1 bar daily
Old Feb 9, 2003 | 09:22 PM
accordfreak's Avatar
$280 is cheap for 440's? i've seen 550's go for $250...
Old Feb 10, 2003 | 05:48 AM
95c1v1cs1's Avatar
Default Re: What cc injectors??? (accordfreak)
440's, 550's, 720's.... I was planning on hondata in the future. I also have a missing link at home. A v-afc right now for minor tuning as of right now. I am just keeping my options open so that i can make my best decision. Should i figure out what management i am using first and then look into what injectors i should use? Thanks
Old Feb 10, 2003 | 06:49 AM
boosted hybrid's Avatar
Go hondata, and get at least 720cc's. I had my 720cc's idling like stock, i am i just upgraded to 900cc's. These will idle like stock as well. If you can idle the injectors, then there is no reason that you would want to go with smaller ones. IMO, if you are planning on a built block and some serious psi 900cc's are the way to go.
Old Feb 10, 2003 | 06:55 AM
95c1v1cs1's Avatar
Default Re: What cc injectors??? (boosted hybrid)
I don't understand if you get hondata that you have to get higher cc injectors... Is there a reason for that?
Old Feb 10, 2003 | 06:59 AM
alpha's Avatar
I would get Hondata and some MSD 72 lb/hr injectors unless you can find the same RC Engineering injectors cheaper.
Old Feb 10, 2003 | 07:09 AM
DefiantGSR's Avatar
you dont HAVE to get large injectors but why not take full advantage of hondata's ability to make any injector idle.
boostedteg4dr
May 5, 2009 02:57 PM
turboant
Sep 27, 2006 03:50 PM
88crxhfb16
Aug 18, 2005 09:40 AM
b20eg6
19
Apr 18, 2002 03:49 AM
smoothludey2
Sep 6, 2001 06:48 PM
