Obd1 conversion on turbo Si
Old Nov 28, 2003 | 03:16 PM
SpdFrk's Avatar
Default Obd1 conversion on turbo Si
okay i got the ecu(p72) i know that i will also need a obd2-1 converter but do i also need to convert to a obd1 distributar and injectors? Im planning on grabing some rc 720cc injectors but what kind should i get saturated or peak and hold for the obd1 conversion?
Old Nov 28, 2003 | 06:11 PM
SpdFrk's Avatar
Default Re: Obd1 conversion on turbo Si (SpdFrk)
anyone?
Old Nov 28, 2003 | 06:22 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">okay i got the ecu(p72) i know that i will also need a obd2-1 converter but do i also need to convert to a obd1 distributar and injectors? Im planning on grabing some rc 720cc injectors but what kind should i get saturated or peak and hold for the obd1 conversion?</TD></TR></TABLE>
You do not need to convert to the OBD1 distributor or injectors. You can keep the OBD2 distributor and injectors. On the injectors....they do not care if the setup is OBD0,1 or OBD2....just make sure that you get the resistor box if you go with the p/h injectors.
Old Nov 28, 2003 | 07:38 PM
SpdFrk's Avatar
Default Re: Obd1 conversion on turbo Si (Blown90hatcH)
Thanks dude.
sixstroke
Aug 12, 2014 02:42 AM
Tonyl507
Feb 13, 2007 09:26 AM
88civicHB703
Jan 6, 2004 05:49 PM
