HELP!!! white smoke out of engine bay
Old Nov 29, 2003 | 08:39 PM
ek9vboi
Guest
Posts: n/a
Default HELP!!! white smoke out of engine bay
i just had turbo for like 2 weeks more or less. turbo is already broken in about 1000 miles and clutch is broken in 500 miles.
i was driving it hard. in 3rd gear around 5k (its a t3/t4 on a d16y8) and out of no where white smoke!!! temp. was ok level. checked coolant, ok...when people say milky, what do they mean by that? like green, but really kind of opque color? mines is green, but no so milky. it doesnt look like oil mixed with it at all. i drove it home w/o any problems at all. its been like 4 days since it happen. so should i be worried??
it has only smoked up that 1 time, but i want to make sure b4 i go tuning. oh yeah, i turned the boost down to like 2lbs now, im scurd shitless. i didnt do a compression test yet.
problems with car:
missing link is fwaked (get check light when it senses boost)
Old Nov 29, 2003 | 08:41 PM
ghettocrxsi's Avatar
Default Re: HELP!!! white smoke out of engine bay (ek9vboi)
Usually white smoke is a blown head gasket. Definatly do a compression test and leak down if you can and they will tell ya whats up
Old Nov 30, 2003 | 08:19 AM
Ri5e's Avatar
Default Re: HELP!!! white smoke out of engine bay (ghettocrxsi)
Smoke from the exhaust? Or smoke from the breather valve?
Old Nov 30, 2003 | 10:29 AM
99B16Si's Avatar
do u have an exhaust leak or are u running open downpipe?
Old Nov 30, 2003 | 10:32 AM
bottlefedb18c1's Avatar
check not just the collant but chack the oil and see if there is water in there
when they say milky that is what i am trying to get too
it wont really look like oil that at all
but do a comp test and a leak down like said above
and you said also that the white smoke was in the engine bay any sigh or where it would of came from?
and just wondering how did you get the boost down to 2 psi?
Old Nov 30, 2003 | 12:33 PM
Foozball26's Avatar
Default Re: (bottlefedb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote"> and just wondering how did you get the boost down to 2 psi?</TD></TR></TABLE>
probably a 2lb spring
Old Nov 30, 2003 | 02:31 PM
ek9vboi
Guest
Posts: n/a
ok, i dont think its a head gasket. i think it was really nothing.
no smoke from exhaust. it was under the hood. when i opened the hood, i didnt see wheree it came from b/c by the time i pulled over, it was all gone.
i checked the oil and it doesn't look like there is any water in it.
i am not running an open exhaust, nor are there an leaky exhaust spots.
finally, i got it down by setting the wg spring down to that much. sounds right...right?
Old Nov 30, 2003 | 03:31 PM
vtec.dc2's Avatar
Default Re: (ek9vboi)
are you running breather filter and is there smoke from breather valve, or maybe smoke from exhaust during startup.. get compression test done..
Old Nov 30, 2003 | 04:24 PM
maybe something was spilt under the hood?
amd yes check by the breather filter also
Old Nov 30, 2003 | 07:07 PM
ek9vboi
Guest
Posts: n/a
i am not running a breather filter. i have an oil catch can connecting from it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">...or maybe smoke from exhaust during startup...</TD></TR></TABLE>
the car was running
anyone?
trus01d1er
Apr 27, 2009 05:35 AM
ragethemachine86
Oct 3, 2006 09:33 AM
Hulk_EJ8
Jun 5, 2006 12:43 PM
bukbukintegra
May 17, 2005 04:45 PM
SIK IN DA HED
Mar 23, 2003 02:09 PM
