OIL return look alright?!?!?!
Old Nov 29, 2003 | 08:37 AM
Neukin's Avatar
Default OIL return look alright?!?!?!
it looks kinda like its going up alittle and the line is kinda bent too much. but.... will this work????
Modified by toyosupr at 3:32 PM 11/29/2003
Modified by toyosupr at 3:33 PM 11/29/2003
Old Nov 29, 2003 | 08:43 AM
Adriano's Avatar
Default Re: OIL return look alright?!?!?! (toyosupr)
It doesn't look too good, but it will do the job. Why dont you get a 45 degree fitting? That would give it a better pitch and wont cling/bend the line.
Old Nov 29, 2003 | 09:14 AM
Ri5e's Avatar
Default Re: OIL return look alright?!?!?! (brryder)
I don't like that bend in the line, it might back up the oil and make your turbo smoke
Old Nov 29, 2003 | 09:17 AM
hulkhb's Avatar
do what brryder said - put a 45 on there and you should be good.
Old Nov 29, 2003 | 09:43 AM
Flamenco-T's Avatar
45 degree hose ends will do the trick..
* one of my customer's car..
stan
Old Nov 29, 2003 | 09:45 AM
Adriano's Avatar
Default Re: OIL return look alright?!?!?! (Flamenco-T)
here is what i mean
Old Nov 29, 2003 | 11:47 AM
RedStarGsr's Avatar
hey guys, this is a lil off topic, but i cant get my flamenco T braided line into the RED portion..how exaclty did you guys do it, just force it through?
Old Nov 29, 2003 | 11:50 AM
ghettocrxsi's Avatar
Default Re: (RedStarGsr)
Make sure you have a nice clean cut on the end. Then take some scotch tape and wrap it around the end like 2-3 times, then put the red end into a vise and push the braided line in while rotating it. should slide right on.
Old Nov 29, 2003 | 12:29 PM
Neukin's Avatar
Default Re: (ghettocrxsi)
45 might do the trick, ill try it. thanks you guys
what about that fitting in the oil pan doesnt it seem to be pointing down... that would mean the oil might not want to travel upwards... yes / no ??
Old Nov 29, 2003 | 12:33 PM
Flamenco-T's Avatar
Default Re: (toyosupr)
as long as you have the 45 degree hose ends, you will be fine..
stan
Dan, try this link
http://www.fast-turbo.com/anlines.html
Old Dec 1, 2003 | 06:24 PM
Neukin's Avatar
Default Re: (Flamenco-T)
well i think that 45 worked its still kinda tight there even after makeing the ss line shorter to make up for the 45 since its longer. i think i have the worlds smallest oil return. the ss line is like 3in and the 2.5 inch 45 degree fitting.
k20em2
Oct 19, 2006 07:24 PM
birz
Jun 4, 2004 06:03 AM
whiteblurr
Feb 5, 2004 02:40 PM
PrecisionH23a
Sep 16, 2003 04:21 AM
ahobbs
Jan 26, 2003 12:36 PM
