map sensor seeing too much voltage
Old Dec 1, 2003 | 12:36 PM
baddassduramax's Avatar
Default map sensor seeing too much voltage
well my car was running good after i put the valve seat in my 35mm tial, until 4 days later, started throwing codes, well i got the code checked and it was...map sensor seeing too much voltage. well im running the safc with dsm 450's at 7lbs boost. if i mess with the safc enough and start my car about 10 time, code will go away for about 15 minutes, then come back on, pretty much now it will only run/idle with the code on and runs like complete ****. what could this be, bad map sensor?
thanks
richard
Modified by civicb18 at 7:22 PM 12/1/2003
Old Dec 1, 2003 | 04:22 PM
Default Re: map sensor seeing too much voltage (civicb18)
ttt
Modified by civicb18 at 10:11 PM 12/1/2003
Old Dec 1, 2003 | 07:11 PM
ttt
Old Dec 2, 2003 | 04:12 AM
apparently no one knows
Old Dec 2, 2003 | 05:12 AM
EE_Chris's Avatar
If the ECU is spitting out a "Voltage to high from MAP", then the settings on your VAFC are not correct. The VAFC trims the MAP voltage and when this voltage goes above ~2.8v, which equals atomspheric pressure, and since N/A motors don't produce boost, the ECU sets a code.
What are your settings for the VAFC?
Old Dec 2, 2003 | 06:38 AM
Default Re: map sensor seeing too much voltage (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
What are your settings for the VAFC?</TD></TR></TABLE>
SAFC not VAFC, doesnt really matter though
well i have tried from -30% all the way across to -50% all the way across, but is what really gets me, it ran for about 3 weeks on settings between -36 to -42 with NO codes whatsoever and now, just like that, its throwing codes and runs like shiat
Old Dec 2, 2003 | 06:48 AM
VTC_CiViC's Avatar
Try swapping in a different MAP sensor.
Old Dec 2, 2003 | 12:14 PM
Default Re: map sensor seeing too much voltage (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Try swapping in a different MAP sensor.</TD></TR></TABLE>
thats kind of what i was thinkin, any more ideas anyone?
Old Dec 3, 2003 | 04:43 AM
up once more
and, where can i get a gm 3 bar?
Modified by civicb18 at 7:57 AM 12/3/2003
Old Dec 3, 2003 | 05:07 AM
99lspwr's Avatar
re-check wiring, and if u can try to borrow someone elses map sensor to try....It def. should not be spitting codes at -40...
Old Dec 3, 2003 | 06:44 AM
Default Re: map sensor seeing too much voltage (99lspwr)
what is the highest/lowest i should be able to run? and for voltage, what should my map see, high/low, WOT, idle, etc?
Old Dec 3, 2003 | 06:48 AM
swlabhot's Avatar
Check and recheck your wiring to make sure nothing is loose. Check all your 'etc' settings (ie., 6in 6out etc...) to make sure nothing has been reset to default values, then check your map sensor..
Old Dec 3, 2003 | 07:18 AM
m R g S r's Avatar
Default Re: map sensor seeing too much voltage (swlabhot)
Like everyone else said, check wiring, it sounds like a wire came loose, because you said it worked fine and now its seeing too high voltage. Also, unless you plan on getting hondata, the gm map sensor won't work with the hack.
Old Dec 3, 2003 | 08:03 AM
Mr. Softee's Avatar
Default Re: map sensor seeing too much voltage (m R g S r)
check afc cofiguration
Old Dec 3, 2003 | 12:02 PM
Default Re: map sensor seeing too much voltage (94goldjungsr)
thanks guys...im gonna check the wiring again, i already did once, but will again
Old Dec 3, 2003 | 12:03 PM
Mr. Softee's Avatar
check the configuration of the afc, if you reset it in anyway it will need to be resetup
Old Dec 7, 2003 | 07:02 PM
well i figured out what was wrong...i had a bad o2 sensor therefore made map see too much voltage, just thought i would fill those in who have helped me out and who care..
thanks
richard
Old Jun 5, 2004 | 05:52 AM
mrx's Avatar
mrx
can you tell me what a faulty o2 sensor has to do with the map sensor voltage??? i don't understand this... maybe i have the same problem but i don't understand why this cause a too high voltage on the map sensor???
Thanks
Malte.
Old Jun 14, 2004 | 07:32 AM
darylfiend11's Avatar
Default Re: map sensor seeing too much voltage (mrx)
bump becuase i would like to kow also
sirhatch90
10
Jun 1, 2006 04:47 PM
chrysler kid
Sep 28, 2004 07:24 PM
silverCRXTC
Feb 4, 2004 07:32 AM
DOHCarp
Aug 23, 2003 11:58 AM
Mugen Mike
Jun 19, 2003 09:19 AM
