Can I use old pistons in a new engine ???
I have a set of SRP piston in my engine right now but I have to rebuit the engine... the pistons maybe have like max 15 000 miles... The engine is a D16Z6.
I have a brand new block who doesnt have been oversized ... so could I use my piston with OEM Honda rings in the new engine or I should use brand new piston ???
Any opinion could be great !
Thank...
Thank...
Re: Can I use old pistons in a new engine ??? (yellowturbo)
If you plan on using OEM Honda rings, you should at least check the ring-to-ring groove clearances and check to see if the clearances and ring thicknesses are up to JE's specs. Sometimes forged pistons will use different thicknesses of rings.
Re: Can I use old pistons in a new engine ??? (IN VTEC)
You can reuse old pistons, however you may want to take them to a machine shop & have them reconditioned & cleaned.
