Anyone ever use MSD injectors with an STR fuel rail
I was wondering if the msd injectors will fit into the STR fuel rail without modification. If not what modification needs to be done and to I take it to a machine shop to get that done?
Re: Anyone ever use MSD injectors with an STR fuel rail (Ek00fbp)
You can either drill the rail to fit the larger injector oring. or you can use two factory orings up top and it should go in fine.
