Wideband or EGT>?
Old Dec 1, 2003 | 09:07 AM
booscivic's Avatar
Default Wideband or EGT>?
I boutgh a plx wideband you guys think I need an egt, or is not needed?
Thanks for your opinions!!!
Old Dec 1, 2003 | 09:09 AM
Johnyquest's Avatar
Default Re: Wideband or EGT>? (booscivic)
As far as I know, An EGT deals some with helping your a/f ratio calibrations, but it's timing that really affects EGT's. I'd just stick w/ your wideband.
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic &raquo;</TD></TR><TR><TD CLASS="quote">I boutgh a plx wideband you guys think I need an egt, or is not needed?
Thanks for your opinions!!!</TD></TR></TABLE>
Not completely necessary but it won't hurt.
Old Dec 1, 2003 | 11:05 AM
booscivic's Avatar
Whats is the EGT for? What can you tune from that?
Old Dec 1, 2003 | 11:30 AM
TeStUdO's Avatar
Default Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic &raquo;</TD></TR><TR><TD CLASS="quote">Whats is the EGT for? What can you tune from that?</TD></TR></TABLE>
EGT is just for exhaust gas temp. It basically good in conjunction with a wideband for ignition timing.
Old Dec 1, 2003 | 11:36 AM
ladysman's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
EGT is just for exhaust gas temp. It basically good in conjunction with a wideband for ignition timing.</TD></TR></TABLE>
Old Dec 1, 2003 | 12:56 PM
Distorted's Avatar
Default Re: (ladysman)
the temp displayed on an exhaust gas meter(pyrometer) represents how rich or lean your running your fuel by temperature, more or less. So if it shows a high tempuerature, say 1400-1600F your running way to lean, and if its showing 600-1000F your probably to rich. You can use this and a cheap narrow band sensor to do some excellent road tuning of fuel curves without a wideband if you know what your doing. I got my fuel just about dead on to 12.5:1 for my turbo set up just on road tuning, only made a few changes at high rpms when i ran a wideband on dyno. I suggest using a wideband and an exhaust gas meter, to help drivabilty and to build a low throttle map for your motor. Running a little extra fuel under low throttle helps keep turbo temperatures low which is always a bonus. It will also alert you to how hot your exhaust is getting and when you should give your car a break from high temperatures. If you dont have one, no biggie! good luck
Old Dec 1, 2003 | 12:59 PM
Mase's Avatar
Default Re: (Distorted)
lol wrong.
Old Dec 1, 2003 | 01:11 PM
booscivic's Avatar
Why are you saying wrong?
Old Dec 1, 2003 | 01:12 PM
Mase's Avatar
changing the timing soley can change the EGT's just as much as any fuel changes can.
Old Dec 1, 2003 | 01:45 PM
booscivic's Avatar
If Im having somebdy tunning with hondata is not really relevant if I have it or not!!!
Old Dec 1, 2003 | 02:00 PM
Mase's Avatar
IF your tuner is worth a ****, he will only need a wideband, you can calculate the correct timing you need.
Old Dec 1, 2003 | 02:21 PM
97F22B2's Avatar
i also have the PLX devices wideband, you will not need the EGT gauge, trust me.
Old Dec 1, 2003 | 03:29 PM
poid's Avatar
Default Re: (Mase)
what kind of calculations can be done to calc the timing needed?
sumo
Jul 30, 2006 09:15 PM
oldschoolfreak
Jan 22, 2005 06:12 PM
jdmstevb16
Mar 16, 2004 10:05 AM
CiViC SiR
Feb 28, 2004 12:17 AM
TeG-DiS
May 26, 2003 05:16 AM
