Can I use a Ford Map sensor instead of a GM 3Bar....
Old Nov 28, 2003 | 10:29 PM
Killer_B's Avatar
Default Can I use a Ford Map sensor instead of a GM 3Bar....
Can I use a Ford Map sensor instead of a GM 3Bar for my Hondata?? I need to know for sure ASAP. I got a Map Sensor from a Lincoln Towncar. Will this work?
Old Nov 29, 2003 | 03:23 AM
Jefnes's Avatar
Default Re: Can I use a Ford Map sensor instead of a GM 3Bar.... (Killer_B)
Sure you can use any map sensor you want....
Provided the output range is 0-5V.
BUT, will the MAP sensor from the Towncar read beyond ~10psi like a stock
Honda sensor? (I don't think so)
Jeffrey Atwood
Old Nov 29, 2003 | 04:01 AM
Killer_B's Avatar
bump....NEED TO KNOW ASAP !!!
Old Nov 29, 2003 | 04:06 AM
Dee's Avatar
Dee
Default Re: Can I use a Ford Map sensor instead of a GM 3Bar.... (Jefnes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jefnes &raquo;</TD></TR><TR><TD CLASS="quote">Sure you can use any map sensor you want....
Jeffrey Atwood</TD></TR></TABLE>
You already got your answer!! If you want the specs on the FORD map sensor you need to call a Ford dealership (probably will not be helpful) or ask about the specs on a Ford related message board.
Old Nov 29, 2003 | 04:11 AM
Killer_B's Avatar
I don't think so is not a definite answer. BTW, i will be using it with Hondata.
Old Dec 2, 2003 | 02:11 PM
h22 civic's Avatar
whats the maodel number on the ford sensor?
Old Dec 2, 2003 | 03:42 PM
evil93evo's Avatar
I think the ford maps read an output in Hz not volts. At least thats what I remember from the fords I messed with.
Tom
Old Dec 2, 2003 | 04:32 PM
Dee's Avatar
Dee
Default Re: (evil93evo)
All Map sensors use voltage as a reference.
Old Dec 2, 2003 | 04:40 PM
Seraph0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil93evo &raquo;</TD></TR><TR><TD CLASS="quote">I think the ford maps read an output in Hz not volts. At least thats what I remember from the fords I messed with.
Tom</TD></TR></TABLE>
You're probably thinking of a MAF sensor. The GM MAF sensors read in Hz. They output a pulsed signal anyway.
Old Dec 3, 2003 | 02:37 AM
Killer_B's Avatar
thanks for everyone who tried to help but the Ford Map sensor is not a 3 Bar. i bought a GM 3 Bar from Autozone ($48) then i took it back becuz a friend is lending the one off his car while it's down.
Old Dec 3, 2003 | 06:08 AM
legendboy's Avatar
Default Re: (Killer_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkC &raquo;</TD></TR><TR><TD CLASS="quote">
You're probably thinking of a MAF sensor. The GM MAF sensors read in Hz. They output a pulsed signal anyway.</TD></TR></TABLE>
Nope, ford 2 or 3 bar sensors output is in ohms not volts.
Old Dec 3, 2003 | 09:10 AM
kpt4321's Avatar
Default Re: (legendboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, ford 2 or 3 bar sensors output is in ohms not volts.</TD></TR></TABLE>
Errr...
First of all, you can't "output" resistance.
Second of all, a GM MAP sensor works by varying the resistance across two terminals as pressure changes, thus changing the way the input 5v signal is split, and thus you get a 0-5v signal.
If the Ford MAP has 3 terminals and varys resistance, it is safe to say that it is compatible. However, I can't confirm this, I do not have any experience.
Old Dec 3, 2003 | 09:31 AM
Killer_B's Avatar
Default Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
the one i used was from a Lincoln Town Car and had 3 terminals but did not work with my Hondata set up for a 3 bar map.
Old Dec 3, 2003 | 11:16 AM
legendboy's Avatar
I was a bit off on the ohms thing, its hertz.
http://www.kemparts.com/TechTalk/tt11.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The above website &raquo;</TD></TR><TR><TD CLASS="quote">
This sensor sends out frequency variations instead of voltage variations. If you were to read voltage on the output wire, you would see a reading of around 1.5 to 3.5 volts. This reading varies slightly with altitude and does not tell you if the output is correct or not. It is merely an indication that the sensor is operating.
The frequency range of the Ford MAP/BP sensor is 92 to 162 Hertz (Hz). An engine idling at sea level may create 17"Hg to 21"Hg. At this vacuum, the absolute pressure is 13"Hg to 9"Hg. (Remember, absolute pressure is calculated by subtracting manifold vacuum from barometric pressure. The output frequency at idle should be 100 Hz. to 109 Hz. This signal varies as the manifold pressure varies.
Old Dec 3, 2003 | 12:23 PM
h22 civic's Avatar
ford wont work any way
Old Dec 6, 2003 | 11:52 AM
PHiZ's Avatar
Default Re: (h22 civic)
Turbo Lincoln Y0h!
-PHiZ
b18_eg
Engine Management and Tuning
Jul 22, 2017 12:31 PM
woojdm
Jun 9, 2009 08:54 PM
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
dseriesdrag
Sep 21, 2006 09:32 PM
