Adjustable fuel pressure regulator question..
Old Nov 30, 2003 | 03:32 PM
BoostedD15B7's Avatar
Default Adjustable fuel pressure regulator question..
Can the ajdustable regulator go below the current pressure or just raise it. For instance. Im running a stock regulator with a 255 intank walbro and that pump raised my pressure up to 50psi at idle. Now can i lower that with and adjustable or will it not go lower because that fuel pump has is at 50psi?
Old Nov 30, 2003 | 03:39 PM
rjardy's Avatar
Default Re: Adjustable fuel pressure regulator question.. (BoostedD15B7)
Yes you can use it to lower the pressure.
Rob
Old Nov 30, 2003 | 03:43 PM
b16ahybrid's Avatar
You just need an actual fuel pressure regulator, not like the B&M fuel pressure riser.
I'm using a AEM fpr with a 255lph holley hp intank pump, i can lower my fuel pressure down to 25psi if i wanted...
Old Nov 30, 2003 | 03:52 PM
94CivSi's Avatar
Default Re: Adjustable fuel pressure regulator question.. (b16ahybrid)
Aeromotive, that's what I'm going with!!! I've heard really good things about it so I don't have any experience with it, but I'm going lots of research on the subject and I'm confident in that decision.
clark
mrx
Oct 31, 2006 11:50 PM
h22 ac
Aug 13, 2006 01:48 PM
tolowhb
Apr 6, 2004 06:42 PM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
iwouldHITit
Mar 8, 2003 09:52 PM
