Boost leak or creeping backwards?????
Old Nov 30, 2003 | 06:24 PM
ATS*Mark's Avatar
OG triple OG
Default Boost leak or creeping backwards?????
ive got the eg greddy kit on my ex motor....i turned in the wastegate actuator screw to up the boost . its just a hair under 8 lbs , but when im under boost at WOT it will go to 8 , then creep down to 5 sometimes , its not all the time , is this normal when you use the actuator trick???
Old Nov 30, 2003 | 07:20 PM
ek9vboi
Guest
Posts: n/a
u must have boost leak then.
8 creeping down wards? weird chit, i gotta c
Old Nov 30, 2003 | 07:37 PM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: (ek9vboi)
Im running a 8lbs spring in my tial . I think something maybe wrong at 3600rpm it will go to a full 5-6 lbs but will not reach a full 8psi untill above 7000rpm any thoughts?????
Old Nov 30, 2003 | 07:40 PM
rjardy's Avatar
Default Re: (gunslinger)
boost leak, check all conections, allso I have heard of the wastegate flapper issues, But I would start small with charge pipes and the like. You just got some new ones so you may want to give them a look
Rob
Old Nov 30, 2003 | 09:32 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (rjardy)
ya i just got the intercooler on and stuff so theres all new piping.....i just thought it was wierd that it would go full boost then back off....wierd
turbo-crx
Jan 24, 2009 09:06 AM
lvf03
Mar 13, 2004 01:57 PM
FUP23
Sep 30, 2002 09:15 PM
Smashback
Jun 28, 2002 02:33 PM
teamrocket si
Feb 10, 2002 02:27 PM
