help with bov...
Old Nov 29, 2003 | 07:40 PM
mattcalica's Avatar
Default help with bov...
okay, i am running a turbo xs rfl at 7 psi, and it really isnt that loud...it sounds just like a greddy type s, but softer. so i am wondering, is the bov even working? is there a leak somewhere? is there a way to adjust it so it lets more air out? or is this about right since i am only running 7 psi. right now, i have to shift at 4500 just to hear a little squeek from it, and i dont think thats good for my turbo.
Old Nov 29, 2003 | 07:49 PM
Ri5e's Avatar
Default Re: help with bov... (mattcalica)
the xs rfl is pretty loud. It's probably too tight, try softening /loosening it up a bit so that the valve opens more when at idle
Old Nov 29, 2003 | 07:53 PM
99blackcivicSi's Avatar
Default Re: help with bov... (BG Boost)
It won't be to the RFL status untill you up ur boost it isn't blowing all that much pressre off with 7psi now at 15psi you will hear it.
Old Nov 29, 2003 | 08:24 PM
mattcalica's Avatar
bg boost, how do i loosen it? do i actually loosen the valve body, or the little nut with the vacuum hose on top?
Old Nov 30, 2003 | 04:19 AM
mattcalica's Avatar
ttt
Old Nov 30, 2003 | 05:01 AM
mattcalica's Avatar
cmon, does anyone know if the RFL is adjustable...just drove the car again, and it sounds like a type s...i dont want that ***** sound, you know? i want to know that i aint getting compressor surge...wheres the whooosh everyones talking about?
Old Nov 30, 2003 | 03:44 PM
mattcalica's Avatar
ttt
Old Nov 30, 2003 | 07:41 PM
mattcalica's Avatar
CAN ANYONE HELP???
Old Nov 30, 2003 | 07:51 PM
rjardy's Avatar
Default Re: (mattcalica)
i think that 7psi is your reason for the low sound. Are these adjustable or do you have to replace the spring to adusjt them?
Rob
Old Nov 30, 2003 | 07:53 PM
rjardy's Avatar
Default Re: (rjardy)
http://www.turboxs.com/racing_...s.htm
found that inlike 2 seconds worth of MSN search. It explains how to adjust the BOV.
Rob
Old Nov 30, 2003 | 07:56 PM
turbod16y8's Avatar
im running 8 psi with the rfl and its a loud WOsShh.... where did u hook up your vacumn line to?
Old Nov 30, 2003 | 10:30 PM
mattcalica's Avatar
the website only shows how to adjust it so it stops fluttering...it doesnt show how to loosen the valve...i hooked my vacuum line up to one of the many vacuum lines on the im...
Old Dec 1, 2003 | 08:00 AM
turbod16y8's Avatar
get a better vacumn. dont tee it off with too many stuff.
Old Dec 1, 2003 | 09:19 AM
quikB18B's Avatar
Default Re: (turbod16y8)
Agreed make sure your BOV has adequate vacuum. Try changing up the order of your lines
blackeg
Dec 4, 2008 04:50 PM
Jayboy
May 12, 2005 10:57 PM
XxRoCkMaNxNEOxX
Nov 5, 2004 07:30 PM
DOHCarp
May 31, 2003 09:17 AM
ebp 99 si
Oct 24, 2002 11:25 AM
