ls vtec turbo setup
Old Nov 30, 2003 | 11:51 AM
ek9turbo's Avatar
Default ls vtec turbo setup
here is the setup:
ls block
81.25 je pistons
9.1:1 compression
eagle rods
balanced crank
type r head, cams, intake manifold
skunk2 springs,retainers and cam gears
msd 6al
drag turbo kit
550 injectors
s100 hondata
dont know the exact specs on the turbo but its a t3t4
on the dyno the deltagate waste gate wont hold the boost, 6psi till like 6500rpm after that boost spike to like 11 psi then drop to like 5psi and so on
the down pipe is 2.25 inches
it made 301 hp and 210 ft/lb torque, graphs will be posted soon
ran 12.1 @ 118 mph 60 ft 2.1
wont get traction untill i shift to 3rd
the motor is in a 96 civic cx hatchback
changed the clutch and the intakemanifold(edlebroke) and tail wastegate
planning to boost like 15 to 17 psi if the injectors supply enough fuel
just waiting till DBL1994 to get his h23 beast ready so we can go back to the dyno
will post the new graphs when we do it
Old Nov 30, 2003 | 11:54 AM
Kwuaymaikrup's Avatar
Default Re: ls vtec turbo setup (ek9turbo)
Throw the Deltacreep in the garbage. Other then that looks good.
-Ryan
Pnoyej6
Apr 18, 2011 05:23 AM
Topdawgg
Feb 23, 2006 04:37 PM
spooledex
Apr 4, 2004 06:53 PM
ek9turbo
Dec 5, 2003 03:37 PM
ek9turbo
Dec 2, 2003 10:20 AM
